Melonized Gear for Small Cap Distributor
Old Jul 12, 2007 | 12:17 PM
Slalom4me's Avatar
Slalom4me
Default Melonized Gear for Small Cap Distributor
Oops. Sorry, Carl Johansson.
The Melonized distributor gear (#10456413) for the OEM Coil-in-Cap
L98 TPI w/ roller cam turns out to have the wrong ID for use with the
External Coil small cap dist used for L98 TPI w/ roller cam in f-body apps.
Can someone confirm that #10495062 is the correct Melonized gear
for the small cap dist w/ roller cam.
Thanks,
Ken R.
Old Jul 12, 2007 | 12:24 PM
JAKE's Avatar
JAKE
Thanks,
Ken R.
WOW! I didn't know that. I may have given a member on another 'F' body Forum the wrong part number.
Thanks for asking that question.
Jake
Old Jul 12, 2007 | 12:40 PM
Slalom4me's Avatar
Slalom4me
Carl has a #10456413 now and the ID is too large for the f-body shaft.
I've used this p/n on an OEM '89 y-body dist.
Old Jul 12, 2007 | 12:57 PM
Slalom4me's Avatar
Slalom4me
#10495062 comes from "Tuned Port Injection" by Frank 'Choco' Munday, ©1995.
However, the number is coming up NLA at an online source.
RockA shows #19052845 for late f-bodies. Here's a typical ex
Distributor Drive Gear
1989 CHEVROLET CAMARO 5.7L 350cid V8 MFI (8) :
1989 PONTIAC FIREBIRD TRANS AM GTA 5.7L 350cid V8 MFI (8) :
ACDELCO Part # 19052845 {replaces 10469459 discontinued}
Can anyone comment?
Old Jul 12, 2007 | 01:03 PM
JAKE's Avatar
JAKE
I used the same 413 gear on the HEI distributor on my 86 Vette and also just used the same one on the oil pump drive in my newly built 96 LT1.
I don't have any experience with the 'F' body distributors, so I can't help with that.
You may be able to find out which one works on the 'F' body by logging onto Thirdgen.org or Camaroz28.com boards. Someone there may know.
Jake
Old Jul 12, 2007 | 01:15 PM
Slalom4me's Avatar
Slalom4me
Thanks.
I was trying to sign in again at 3G earlier but the site has been slow
and I wasn't successful.
Old Jul 12, 2007 | 02:17 PM
JAKE's Avatar
JAKE
Thanks.
I just logged onto the thirdgen site. Took about 30 seconds to reach the Message Boards.
When you have time, give it another shot.
Jake
Old Jul 14, 2007 | 03:59 PM
Slalom4me's Avatar
Slalom4me
Useful info parsed from Gilbert/Sallee
HEI Distributor Gear: Melonized - Must use with OEM roller cams.
  • 19052845 - Small Cap (.425”).
    This is a hardened gear. Fits some Mallory distributors. [Old P/N 10469459]
  • 10456413 - Large Cap (.491”). Part of distributor assembly P/N 1104067.
To Melonized Gear for Small Cap Distributor
