Delteq Opti-Direct Ignition
Old Jul 13, 2007 | 10:38 AM
Glen Green 65's Avatar
Glen Green 65
Default Delteq Opti-Direct Ignition
Has anyone used the Dleteq Optisaprk replacement iginition system?
If so any problems?
Old Jul 13, 2007 | 01:39 PM
Tom Piper's Avatar
Tom Piper
On a scale of 1-10, my Delteq is a 50.
Tom Piper
Old Jul 13, 2007 | 02:20 PM
FD2BLK's Avatar
FD2BLK
Yes, I installed the Delteq about three years ago and love it. Have I had problems, yes but the tech support from Pete and JC is second to none. The first problem I had was I bought a bad Opti from GM but Pete worked with me for about a week to help me find a problem that had nothing to do with the Delteq system The second problem just happened about 3 months ago, my car would just up and die for no reason then I could wait about 2-5 Min and it would start back up. JC sent me a new Opti box and I was back in business.
Old Jul 13, 2007 | 03:20 PM
SJW's Avatar
SJW
The Delteq DIS conversion package is a good product, and Delteq is a good company to deal with. Just be aware that the system only replaces the high voltage (distributor) section of the Opti. The optical camshaft sensors in the Opti must still be present and functional. That's not a knock on the Delteq, but is something of which you should be aware.
Be well,
SJW
Old Jul 13, 2007 | 04:29 PM
81ProStreet's Avatar
81ProStreet
7th Gear
I installed the Delteq system on my 96 after my local chevy dealer said my Optispark was bad. It had a complete MSD cover installed. I just removed the plug wires and installed the Delteq per instructions (performing each check along the way) and all my miss went away and has stayed away. The main difference is the Delteq takes several turns of the starter to start, where my opti fired the motor instantly.
Old Jul 13, 2007 | 05:04 PM
Kinkajou's Avatar
Kinkajou
Customer service is awsome. It is great. Pete is 100% behind his product.
That alone is worth the system!
Old Jul 16, 2007 | 08:29 AM
Glen Green 65
I have heard that the bailey unit is good, however it is not a compete kit, you must make your own mounting bracket and such. My Opti is getting old and I know it is just a matter of time. The Delteq seems the way to go.
Old Jul 16, 2007 | 08:34 AM
Road Agent's Avatar
Road Agent
Tom Piper
Tom Piper's Avatar
Tom Piper
Originally Posted by Kinkajou
..Pete is 100% behind his product.
I think Pete moved on and is no longer at Delteq.
But, J.C. is just as good.
Tom Piper
Old Jul 16, 2007 | 03:38 PM
Mojave's Avatar
Mojave
Originally Posted by Glen Green 65
I put an LTCC setup on my car, and yes, you have to make some of your own parts.
Here is my setup:
Old Jul 16, 2007 | 04:06 PM
lefoy84's Avatar
lefoy84
Mojave,
Did you fabricate the coil brackets yourself?
I have been considering the LTCC.
Old Jul 16, 2007 | 06:18 PM
Mojave's Avatar
Mojave
Originally Posted by lefoy84
Mojave,
Yeah. I welded threaded hex standoffs to the valve cover bolts. I put the coils on pieces of all-thread. I made L brackets that bolt to the standoffs and the all-thread.
If you don't have the LT4 valve covers with the large bolts, you could probably weld the standoffs to the metal valve covers.
Old Aug 14, 2007 | 08:33 AM
The Evil Genius's Avatar
The Evil Genius
From: Dayton, OH HAWG: "this is Off Topic...it can get a bit north of care bears and strawberry shortcake in here"
For anyone that instaleed a Delteq system, what do you do with the cap and rotor? Just leave them in place and unplug them?
Old Aug 14, 2007 | 08:43 AM
Mekanic's Avatar
Mekanic
You will still need to replace the opti if it goes out. Delteq or no.
Old Aug 14, 2007 | 11:22 AM
Ramrod92's Avatar
Ramrod92
Cruise-In II Veteran
Here's the Delteq mounted on my 92, along with the Dyna spark opti for the signal. And if you want the coolest cover you can pick up one of these for about $100.
Old Aug 14, 2007 | 12:03 PM
steve40th's Avatar
steve40th
St. Jude Donor '03 & '05
Delteq is great. I cut the rotor off of the Opti, loctited the rotor down, RTV'd the thing to hell and back and moved on. The DELTEQ has one feature that needs help, getting a tach shift light to work. I know I got allotof help rom guys, but my MSD shift light just wouldnt work. I think the MSD tach adapter that goes under the coil is the answer. But, other than that, this thing is great.
And Baileys LTCC is awesome too, and no complaints from anyone that I know of.
Old Aug 14, 2007 | 07:07 PM
hgh pwr's Avatar
hgh pwr
what about the plug wires for the deltag,looks like a custom set so if one gets burned can you buy replacements,the ltcc takes ls1 plug wires.both look like great products.
Old Aug 14, 2007 | 11:32 PM
steve40th's Avatar
steve40th
I bought a set of wires and connectors from Taylor, then a crimper from Taylor and did my own. After doing this I realized I had been wasting money for years because I didnt do this myself. It was too easy.
To Delteq Opti-Direct Ignition
