Air vent removal....How?
Old Jul 13, 2007 | 04:24 PM
vetteboy95's Avatar
vetteboy95
Default Air vent removal....How?
How do you get the air vent out of the passenger side dash on a 95. Does the bottom of the dash have to come off? It is partially out and I would like to get it back together.
Thank you.
Old Jul 13, 2007 | 05:50 PM
Red Dwarf's Avatar
Red Dwarf
You have to remove the small louvered section in the middle by prying up, gently, with a small flat bladed screwdriver.
After you get that off you shud see 2 screws, forget the size, that holds the main vent. The movable parts are very fragile.
Old Jul 25, 2007 | 05:15 PM
vetteboy95's Avatar
vetteboy95
I was out of town and haven't had a chance to check this. I just need to get the louvered part out and put it back together properly. So it just pops out by prying on it. Didn't seem like it wanted to come out that way but I'll try it.
Thanks.
Old Jul 25, 2007 | 10:18 PM
Red Dwarf's Avatar
Red Dwarf
Thanks.
It's the small section in the very center. Pry from the bottom up, this is according to the FSm, Have done it with no problem.
What exactly is the problem with the louvered section...are you referring to the small center piece that is the problem?
Old Jul 25, 2007 | 10:26 PM
RRT vette's Avatar
RRT vette
pretty simple.
To Air vent removal....How?
