Who sells chips for socketed PCMs now?
Old Jul 14, 2007 | 03:49 PM
HJV11's Avatar
HJV11
Default Who sells chips for socketed PCMs now?
Its been a long time since I have had to buy a set and need to know who is selling 94/95 PCM flashable chipsets.
Thanks in advance.
Old Jul 15, 2007 | 04:58 PM
HJV11's Avatar
HJV11
TTT
Anyone??
Old Jul 16, 2007 | 12:11 AM
VenkmanP's Avatar
VenkmanP
Been a few years since I bought some, but they are just standard memory chips you should be able to get from any electronics supply house.
Mouser, Digikey, Allied, etc.
Old Jul 16, 2007 | 08:45 AM
HJV11's Avatar
HJV11
Interesting, I did not think you could just purchase the chips and upload the program fresh. I thought for some reason someone had to do the initial upload. I guess I thought you had to have a different method of uploading the initial flash.
Thanks for the reply! If anyone has gotten some recently please list your source.
Old Jul 16, 2007 | 10:16 AM
kalister1's Avatar
kalister1
On my 93 you need to change the chip or burn a new program into the old chip by removing it from the ECM. I THOUGHT? that the 94 and up can be flashed while in the PCM through the ALDL? No need to change the chip.
Old Jul 16, 2007 | 11:16 AM
VenkmanP's Avatar
VenkmanP
That probably is the case. I've never tried putting a blank chip directly in the PCM - I used a PROM burner. I think it has to have boot code before you can flash using the PCM.
If you want one that's already programmed, then I recommend madz28.com
Old Jul 16, 2007 | 01:31 PM
Tuner@Straightline's Avatar
Tuner@Straightline
For blank chips, I like using the moates.net GP1 adapter with chip set.
Old Jul 19, 2007 | 07:27 AM
96lt4c4's Avatar
96lt4c4
Thanks in advance.
Also use www.moates.net
To Who sells chips for socketed PCMs now?
