95-C4 Automatic door locks
Old Jul 18, 2007 | 08:39 PM
c4craze's Avatar
c4craze
2nd Gear
Default 95-C4 Automatic door locks
Here is a strange one. I really would appreciate any thoughts or comments.
Driving with doors locked, if you hit a good bump in the road the autolocks will unlock both doors. Able to recreate the problem by hitting drivers side door. Removed the panel to check for shorts, loose connectors, etc. nothing found.. Are we missing something here.
Thanks for the help.
Old Jul 18, 2007 | 08:45 PM
VenkmanP's Avatar
VenkmanP
There is no "autolock" unless you have something aftermarket.
Your problem, if it's stock, is most likely door ajar switch. Second most likely is door alignment.
