Battery or alternator?
Old Jul 19, 2007 | 04:54 PM
StephensblackL98's Avatar
StephensblackL98
Default Battery or alternator?
I hate electrical problems; fortunately they don't happen often.
Yesterday, coming home, my car hesitated at a stop light. That is, idle went down to the point of nearly stalling out. I went to a gas station, filled up, got in an heard nothing but a click of the starter. There was not enough juice to turn the motor over.
I called my wife, who brought jumper cables. Jumped it, and it died as soon as I took off the cables. Jumped it again, and it kept running. Going home I noticed the gauge was not quite up to 12 volts; it had always run at 14 or so. My guess is that the car was running off the battery, which finally just gave up because the alternator wasn't charging it sufficiently.
To cut to the chase, is best guess the alternator? Or, the battery? I'm taking the battery now to be checked. It's pretty old. My fingers are crossed it's gone. The alternator doesn't appear to be very difficult to swap out, though. If it makes a difference, it's a '93 model.
Anyway, thanks very much for the input. As always, I very much appreciate your help.
Stephen
Plano, Texas
Old Jul 19, 2007 | 05:25 PM
86PACER's Avatar
86PACER
Use a multi meter set to the voltage scale. There are two easy ways to check the alternator. As soon as the car starts up, the volage at the battery should jump to about 13-14 volts and stay there untill the engine is shut off. Touch the negative lead of the meter to on of the master cylinder mounting bolts for ground. Then with engine running, touch the positve lead to the positve of the battery, the to the thick red wire attached to the back of the alternator. Complare readings. They should be the same and should always be about 2 volts higher than when the car is off.
Also, get a flat blad screwdriver and touch it to the back center of the alternator while the engine is on. If it sticks magnetically, the alternator is working. If not, the alternator is not charging.
Old Jul 19, 2007 | 05:37 PM
94z07fx3's Avatar
94z07fx3
If you do replace the alt be careful with the plastic clipped on connector on the bottom. I managed to break mine and was fortunate to find the connetor in the HELP isle. Mine had gotten brittle but even so I wasn't ginger with it.
Old Jul 19, 2007 | 05:49 PM
BADDUCK's Avatar
BADDUCK
From: One day you're a Comet...the next day you're dust... Arkansas
I never guess unless I have to. You are doing the right thing, check the battery first then the alt. It could also be a loose positive cable. The symptoms can be just as you described.
Old Jul 19, 2007 | 11:06 PM
jfb's Avatar
jfb
If the alternator was not charging the battery, the battery symbol light would have been lit on your dash. If not, then you have some other problem, but your low battery voltage indicates the alternator could be defective or you could have a shorted cell in the battery making it a 10 volt battery and heavily loading the alternator dragging its output voltage down. You are doing the right thing by having your battery checked and the next thing is to have your alternator checked. Most parts places can check your alternator in their store and some can check it in your car if you can get it there!
Old Jul 20, 2007 | 09:18 AM
89 Bob L's Avatar
89 Bob L
Sounds like an alternator, but you can do some simple steps before going for a new battery and/or alternator. First, check your positive and negative connections on the battery, clean and tighten as necessary. Check the grounds, there should be one on the frame, driver's side near the alternator. Check the connections to the alternator, making sure they are clean and tight. A can of connector cleaner will help. Have the battery checked to make sure you do not have a dead cell.
It appears that the alternator is not putting out. Typically, if the car is running and you remove a connection to the battery (not recommended) the car should continue to run. If it stalls, it indicates the alternator is not putting out, thus causing the car to run on the battery and thereby draining it.
Many auto parts stores will test the alternator for free.
Old Jul 20, 2007 | 10:40 PM
Lichen's Avatar
Lichen
My first guess is the battery (how old is it). Mine was fine at noon, but at 3pm, it was totally dead (stupid AC Delco)!
Old Jul 21, 2007 | 08:11 AM
Paul Workman's Avatar
Paul Workman
Default Yep!
I agree w/ you on every point, being of the electronic persuasion most of my life.
P.
Old Jul 21, 2007 | 08:18 AM
golfman2008's Avatar
golfman2008
St. Jude Donor '05
" Turn Your Bottom Breather Into a Ram Breather "
http://www.C4orceCorvette.com
Old Jul 21, 2007 | 08:45 AM
StephensblackL98
Thanks, everyone,for all the assistance! It turned out to be the alternator. However, I was pleasantly pleased that a rebuilt alternator (with lifetime warranty) was only $100 at O'Reilly's.
That said, 94Z07 was 100% right about the plastic connector. I wasn't careful enough in removing it - the one at the back, and bottom that brings the wires from the harness to the alternator. I broke mine. The replacement from a dealer was $62 - nearly as much as the alterntor. Moral is, be very careful in removal, particularly if it's as brittle as mine was. The replacement, by the way, came with one foot of connecting wire to splice to the original wires. Not difficult to do, but time consuming to do correctly.
Again, thanks very much for pointing me in the correct direction. For those curious, the car in my avatar is not the one that had the problem. I have a thing about '93's. The problem was on my coupe.
Stephen
Plano, Texas
Old Jul 21, 2007 | 10:09 AM
davidnclearlaketx's Avatar
davidnclearlaketx
Glad you got her back up and running.
I had the O'Riley's GM rebuilds lifetime warranty on for a long time-a few years at a time. The first one lasted about a year then the 2nd and 3rd seemed longer.
Keep the receipt in the car and the wrenches in the bins behind the seats!
Just in case!
Just my luck they always fail in the hot, humid Houston summer and I even had to change it out in the auto parts parking lot one time!
Good luck!
To Battery or alternator?
