Hello, I have a 95 C4 with only 70K miles. It's on it's 4th water pump. I only use Delco pumps. Any thoughts as what is happening? Can the spline connector tube be too long and is placing a load on the pump bearing?
that's an average of 17.5K miles per WP. Either you have had extremely bad luck from your source of the OEM WP(which I doubt) or you definately have another issue. When they fail, is the WP leaking from the weep hole, or is there another failure mechanism involved like loud "scratching" bearing noise? When you install a new WP, there should be not resistance during mounting procedure. If you have to add any additional force when fitting the new WP to the front to the engine, then yes, your connector spline may be to long causing premature bearing wear due to forward/uneven pressure on the bearings.....
My Delco lasted 40K, thats the total miles on the car. I was not about to put that same brand on it again, a pump should last a lot longer than that. I got a lifetime warranty pump at Auto Zone, about $100, and Ill never buy another one again.
MikeC4 has made some good points. Several things may be happening. Check the water pump pulley to make sure it is not bent and it is properly lilned up. If it is bent or misaligned it will cause undue stress on the water pump bearings. Check the tensioner to ensure it is not putting too much pressure. check the belt to make sure it is the correct size.
That's perfectly sound advice for the vast majority of cars ever made. But not for the LT1 or LT4 with the gear driven pumps.
If one were to take the kernel of wisdom from Bob and apply it to the LTx he would look to the timing set's output shaft and make sure it wasn't tight agianst both the pump and the timing cover at the same time.
There was a great write up on converting the LTx pump to electric and I've thought about it for the oh ah factor but if I had gone through four gear driven pumps I would certainly be looking at it just to keep her on the road.
<edit> Oh I just had an idea. (rare that!) What do you guys think about him installing two gaskets instead of one? It would make the distance from the timing cover to the back of the pump just a bit longer. Would that hurt anything if clearance wasn't the problem? Would it help if clearance was the problem?</edit>
Sounds like it is time to consider the electric pump~!
Here's a thought:
The sleeve that connects the water pump driven gear to the water pump has a groove around one end....even though you can make it work either way, it is supposed to go on one way.
That groove goes toward the timing cover -- not the water pump.
Here's a thought:
That groove goes toward the timing cover -- not the water pump.Tom Piper
I puzzled my puzzler over the same issue - which way the groove should face - when I was assembling my new 388. Finally found a photo of which way it should face - toward the engine NOT the radiator.
I didn't, and still don't, know what difference it makes but "why take a chance" was my thinking.
Hi Mike, it leaks from the weep hole. I looked at the orings that cap the spline connector; they are pretty smashed. I did not have a tough time mounting the new pumps. I'll try shaving .02 off the connector.
