jfb dome light will not go off,
Old Jul 21, 2007 | 10:44 PM
nickpe's Avatar
nickpe
Default jfb dome light will not go off,
i figured out why the past owner had the dome fuse out. it wont go off, draining batt. radio works great.any ideas on dome.
Old Jul 21, 2007 | 10:51 PM
94z07fx3's Avatar
94z07fx3
Are the little door plungers working? One of mine stuck so I sprayed it with some Si and gave it a whack with a rubber mallet.
Old Jul 21, 2007 | 11:31 PM
ecorse66's Avatar
ecorse66
There is also a Courtesy Light Delay Timer Module that may have gone bad. According to the Service manual it is "behind the RH side of the multi-use center." I assume that means behind the center or right-hand side of the instrument panel. You might be able to unplug it and see if the lights go out.
Dave T.
Old Jul 22, 2007 | 01:27 AM
jfb's Avatar
jfb
If you unplug the courtesy light delay timer, the courtesy lights will not come on. The courtesy light timer is activated by the left and right door jam switches. My money is on a defective door jam switch or the wire going to the door jamb switch has its insulation cut and is shorted to ground. The door jamb switch is open circuit with the doors closed. Your courtesy lights stay on because the door jamb switch is grounded all the time or the courtesy light delay timer is defective. Unplug the delay timer and use an ohmeter to determine if pin D on the timer socket (white wire) has low resistance to ground with the doors closed. It should be open circuit and if it is, then the delay timer module is probably defective.
To jfb dome light will not go off,
