Electrical mystery solved??????????
Old Jul 21, 2007 | 11:23 PM
dans87vette's Avatar
dans87vette
Default Electrical mystery solved??????????
Well, I've been chasing a short in my 87 for some time now. For some reason my "tail light" fuse blows within hours of driving my car at night. I first checked all sockets and any wires/grounds and all looked good, until I realized my fog lights and front signal are also on this circuit.
So I found a turn signal buld with one of it's elements loose and touching the other element (its a two element bulb), could this cause a short??
I also found that the fog light bulbs were replaced with a wrong model number and the Watt's on them were 37.5 compared to the new stock ones I bought were 27 Watt's.
I haven't had a chance to go for a long ride and test to see if this will fix my fuse blowing problem. Do you think either of these could have been the cause??????????
Old Jul 22, 2007 | 01:23 AM
vinnies87's Avatar
vinnies87
St. Jude '03-'04-'05-'06-'07
If you have the larger fog bulbs, then the fuse should have been upgraded to a 20,,, search and theres info on this...
Old Jul 22, 2007 | 10:02 AM
dans87vette
Then that may have been the problem, it was a 10 amp in the system. I changed backed to the stock bulbs.
To Electrical mystery solved??????????
