Head gasket replacement...
Thanks!
A TTY bolt is first pre-loaded to an initial torque value, next it is
tightened to a specified torque value and lastly tightened an additional
specified number of degrees of rotation.
When under load, ductile materials have elastic, plastic and rupture
regions. Parts that are tensioned only to loads within the elastic
region may stretch under load, but they will return to the original
length when the load is removed and there will not be a reduction in
cross-section along the length of the part.
'Torque-to-Yield' intentionally tensions a fastener past the Yield Point
(the upper limit of the Elastic region). This permanently streches
the part and somewhere along the length, the cross-sectional size
narrows.
Engine rebuilders who reuse TTY fasteners are either doing so for
economic reasons or because they don't know any better. In either
case, they are gambling with the customer's money.
Part of the point of using TTY head bolts is to eliminate the need to
re-torque the bolts over time to compensate for gasket compression.
At best, a used TTY bolt won't be able to apply the same clamping
force and the gasket will leak sooner. At worst, the bolt will break
during installation or while in service, possibly causing other issues
besides the need to replace the bolt/repair the threaded hole.
Instead of using new 'Torque-to-Yield' bolts, traditional 'Torque'
bolts could be substituted. In this case, be sure to research and
follow any applicable guidelines regarding retorquing the head bolts
after several heat-cool cycles and then at regular intervals.
Be careful to keep the 'nut' on the case side of the cable end from
turning while loosening the cable retaining nut. Ideally, use the
correctly sized thin ignition wrench. Alternatively, use needle-nose
pliers. If the stud turns, a conductor inside the case can break - you
then need to disassemble the alternator to repair the broken conductor.
The cable to the alternator is electrically 'hot.' Disconnect the battery
ground cable before beginning to work.
My vote is that aluminum heads seldom crack. The much more common
problem on C4's is corrosion arising from electrolysis.
Is there a head gasket kit from GM that includes all gaskets and seals from the heads up? Anyone have a part number?
Chris May at Superior might be able to help.
Fel-Pro #HS7733PT9 is a top end kit that includes gaskets for the
head, int/exh manifolds, runners, plenum, throttle body & ect.
However, it appears to be specified across several years - not just
for the '91. As SunCr mentioned, the '91 had features the earlier
engines didn't.
You will probably will have other questions as you go, but this gives you a decent start. After all, you HAVE been here before. You have nothing to fear, but fear itself.
RACE ON!!!
