Mysterious Service Engine Light
Old Jul 24, 2007 | 09:23 PM
Redzoom's Avatar
Redzoom
Default Mysterious Service Engine Light
This is on a '96 LT1. Service engine light came on and stayed on two days and 60 miles, then went out. I thought it stayed on until the problem was fixed and the light was reset. So, does the light go out and the problem remain, or if the problem resolves itself does the light go out. I had just ran a bottle of techron through the tank and refilled it, so maybe that had something to do with it?
Old Jul 24, 2007 | 09:37 PM
lefoy84's Avatar
lefoy84
The DTC should still be stored. All you need is a paperclip!
Old Jul 25, 2007 | 07:51 AM
runner140*'s Avatar
runner140*
You have an OBD11 computer. Go to fleaBay and get for $19.95 a OBD11 code reader. It come with a manual and an explanation of all codes and will also erase those stored codes. It has saved me much time and with a factory service manual, it will save you tons of money.
Old Jul 25, 2007 | 07:59 AM
vetteblack's Avatar
vetteblack
If the light is out, it has resolved itself, not saying it wont come back on. You may want to read the code, to see what it was.
Old Jul 25, 2007 | 09:25 AM
eschoendorff's Avatar
eschoendorff
St. Jude Donor '08
Sounds like Code 32...
Old Jul 25, 2007 | 10:20 AM
trackman44's Avatar
trackman44
Default OBD II code reader
OBD I uses the paperclip method, OBD II needs a code reader ('96 and newer vehicles).
Old Jul 25, 2007 | 10:23 AM
94z07fx3's Avatar
94z07fx3
Advance or AutoZone will read your codes for you or let you borrow their reader.
Get the code for free and then order your own scan-a-ma-jig.
Old Jul 25, 2007 | 06:19 PM
Redzoom's Avatar
Redzoom
Good information you guys. Thanks. There is an Autozone down on the corner from me, and I will go see if I can use their code reader. I may check on E-Bay for a reader also. Thanks again.
Redzoom
Old Jul 26, 2007 | 09:27 AM
onedef92's Avatar
onedef92
Cruise-In IV Veteran
Cruise-In VI Veteran
Cruise-In VII Veteran
Cruise-In VIII Veteran
AutoZone will also give you a freebie code-reader key ring. I keep mine in my console for when it comes time to check codes.
To Mysterious Service Engine Light
