Replacing water pump
Old Jul 25, 2007 | 11:39 PM
ubnpast's Avatar
ubnpast
Default Replacing water pump
Well I know this has been gone over many times, I recently mistaken the leak in my engine bay for my power steering rack, although I smelt some antifreeze.
I have a 96 lt4 and today I looked at the weep hole again and it is wet, so my question is how long will the water pump last as it is for right now?, sometimes it gets underside of the hood somewhat wet from the belt throwing the coolant.
I understand that I dont need a service manual, but I bought the red covered one (book 2), im hoping that is the correct one because I got it for $60 shipped.
Now I do have somewhat of a budget with college in mind, dont get me wrong Im not looking to take the cheap way out.
I was looking around and saw I should replace the waterpump, upper and lower rad. hoses, thermostadt and also flush the dexcool out and throw the green stuff in there, any thing else I should look at?
Should I get non oem rad hoses and thermostadt?
I seen some guys about the electric water pumps, but they said something about removing the oil pan for some reason, and my car being a collectors edition I think it is just best to stick with oem, even though it only lasted 45k miles .
Old Jul 25, 2007 | 11:50 PM
vinnies87's Avatar
vinnies87
St. Jude '03-'04-'05-'06-'07
The top question is: How long before your WP leak damages your Opti, then you'll have double the fun and expense... But on general principles:
WP
Hoses
Thermo's are cheap (but test before install - pan of water and see if opens at temp stated)
Def flush and go green
ACDelo parts are fine.
Yea Opti and wires while your down there.
Old Jul 26, 2007 | 12:05 AM
ubnpast's Avatar
ubnpast
WP
Hoses
Well is it neccessary to replace wires? The car runs great right now, so I think those and the opti can wait until they both go.
Old Jul 26, 2007 | 12:48 AM
enventr's Avatar
enventr
how many miles are on the car?
Old Jul 26, 2007 | 12:51 AM
STL94LT1's Avatar
STL94LT1
AC/Delco water pumps come with a new thermostat.
Old Jul 26, 2007 | 12:54 AM
ubnpast's Avatar
ubnpast
45k.
Thats good info.
Old Jul 26, 2007 | 02:16 AM
94z07fx3's Avatar
94z07fx3
Thermostats are cheap and the lifetime warranty pumps are less than $150. So it could be the last pump you buy and you will save enough to buy a drawer full of thremostats. Lifetime warranty Stant thermostat $20.
Old Jul 26, 2007 | 06:11 AM
enventr's Avatar
enventr
IMO I would change everything (vinnies87) but considering you have 45k miles if you dont have the money then dont.You should do this asap.If the opti goes at 60k miles you would have to redo the waterpump.I had my opti till 75k and then because of leaks,replaced every gasket,wp,opti and wires and hub.(95LT1)some people have opti's till over 100k but you never know and alot of labor is involved
good luck
Old Jul 26, 2007 | 09:45 AM
Casethecorvetteman's Avatar
Casethecorvetteman
Book one is the book you need for the water pump, book 2 is the drivability and emissions book.
I wouldnt leave it too long at all, youre risking damage to other components by letting it go like this.
Sure do
Old Jul 26, 2007 | 07:11 PM
ubnpast's Avatar
ubnpast
Well thats not so good news, doesnt book 2 include engine & transmission? And I figured waterpump would be with the engine..
Well im out looking for book 1 I guess.
Sure do
Old Jul 26, 2007 | 07:17 PM
Smooth's Avatar
Smooth
Default From Who??
I just did a search and found a lot of lt1 pumps were over $200....Who is your source?
alan
Old Jul 26, 2007 | 07:20 PM
ubnpast's Avatar
ubnpast
I found thepartsladi had them for 182 shipped.
Old Jul 26, 2007 | 07:46 PM
94z07fx3's Avatar
94z07fx3
alan
If they were a forum sponsor I'd link ya up. But you'll have to go to advance auto parts' web site and shop online. Enter a profile for your vehicle. etc.
Part No. WP9001 lifetime warranty 142.88
Old Jul 26, 2007 | 07:51 PM
compyell95's Avatar
compyell95
If you're on a budget, do keep in mind that opti's are expensive unless you can get them wholesale. I guess what I am saying is at least fix the waterpump so you don't destroy your distributor and HAVE to spend the money on it. I just replaced mine after I hit 100k but had replaced the waterpump at about 60k after mine did the same thing yours is doing.
Old Jul 26, 2007 | 08:14 PM
Smooth's Avatar
Smooth
Thanks!
Old Jul 26, 2007 | 08:41 PM
ubnpast's Avatar
ubnpast
Just another question, is a "j 38185 spring hose clamp pliers" needed?
Does the AC Delco water pump come with new J39089 Coolant pump shaft o-ring protector (is it needed)?
Old Jul 26, 2007 | 09:03 PM
Casethecorvetteman
No, "j 38185 spring hose clamp pliers" are not needed, and no, J39089 Coolant pump shaft o-ring protector is not included.
You shouldve got them both to begin with, cause there is information in both that you can and will use if you have them there.
To Replacing water pump
Old Jul 26, 2007 | 09:11 PM
jrzvette's Avatar
jrzvette
From: The reason time exists is so everything doesn't happen at once
A few things to keep in mind.
The opti does not have to be removed to change the waterpump, but the wp has to be removed to change the opti. This is why most guys do both at the same time.
If your opti isn't giving you any trouble (and at 45k miles it should be ok) leave it alone to save money. But don't ignore the leaking waterpump. It might seem like a small leak but it can let go without further warning and take out the opti.
Even though you think you've totally drained the cooling system, cover the opti with plastic wrap and shop rags. There may be some coolant left in the wp when you unbolt it from the block and it will get the opti.
If you're going to switch from dexcool to green make sue you get every drop of the old coolant out of the system. The two don't mix and the result is a jelly-like goo that will completely screw up the engine.
Where in NJ are you located? Maybe a member nearby can loan you FSM book 1 or lend a hand.
Old Jul 26, 2007 | 11:22 PM
ubnpast's Avatar
ubnpast
does the "J39089 Coolant pump shaft o-ring protector" need to be replaced, idk why its mentioned in the manual.
Im near clinton, I think I can tackle the task myself, it seems straightfoward. Ive pulled honda heads, water pumps, timing belts and replaced everything with no problems, so I think this should go the same way.
A very nice forum member sent me scans, 4 pages, from book 1 which include details on it.
Would you recommend me draining all the coolant out prior to wp removal and filling with regular water then run, let cool drain, then repeating the process 2 more times? I think that should drain/clean out the dexcool in the system.
Will 2 premixed gallons be plenty you guys think?
Old Jul 27, 2007 | 05:20 AM
enventr's Avatar
enventr
Dont forget to put the heater on to circulate the old fluid when flushing.BTW the new prestone is compatible with dexcool but try to flush out as much as possible
