EGR question "diode trick"
Old Jul 28, 2007 | 04:48 AM
Cartier1's Avatar
Cartier1
Default EGR question "diode trick"
Hi everybody!
i have a question about the EGR disable,i took out the EGR valve,and leave the solenoid connected,i did it when i installed the Superram and headers,but seems like my car is not idle right it is unstable sometimes,and feels heavy when i hit the throttle ,i checked for leaks and everything seems to be ok,maybe the reazon is that egr problem i have not a reprogramed chip,but i heard about a diode trick for the solenoid,is that a good mod for that????
anyone has the link???
Thx!
Old Jul 28, 2007 | 11:02 AM
Aardwolf's Avatar
Aardwolf
With the valve removed, it cannot be doing anything. On my car I cut the wires and tied them back, you do not need them hooked up. The diode trick would not do anything as far as I know, since with mine disconnected it does not get codes. 65ZO1 has the diode information on his site here: http://www.geocities.com/jgkov/index.html
Old Jul 29, 2007 | 05:28 PM
Cartier1's Avatar
Cartier1
Thanks for the help i will disconnect the wires and see if doesnt send any troube code or turns on the service light.
Old Jul 29, 2007 | 07:23 PM
coupeguy2001's Avatar
coupeguy2001
2021 C4 of the Year - Modified Finalist
Default egr
1.if I unplug my egr solenoid, I get a code.
2.If I disconnect the egr sensor, I get a code.
3.I am guessing, that if you ohm the egr solenoid coil, and solder a resistor of that value to the egr connector pins, and use a hose clamp, clamp the egr sensor to the exhaust manifold, it would not throw a code.
Old Jul 30, 2007 | 11:05 PM
Cartier1's Avatar
Cartier1
coupeguy2001 is right,if i unplugged the sensor,the service light turns on,i think i need that diode,but on the link doesnt says the value of the diode,do you guys know the value for that??ohms????
Old Jul 31, 2007 | 01:03 AM
coupeguy2001
Default diode
diodes are one-way electrical gate valves. They only pass electricity in one direction.
a diode isn't what you need, shat you need is a resistor.
the computer is resistance based. If you replace the egr solenoid with a resistor, you can fool it into thinking that the egr solenoid is still connected.
Old Jul 31, 2007 | 01:42 AM
Cartier1's Avatar
Cartier1
just another question!
does the car runs better with the resistance instead the EGR solenoid??
i mean just the solenoid without hoses and egr valve??or the solenoid does the same function???
Old Jul 31, 2007 | 05:21 PM
coupeguy2001
Default egr
the solenoid is a vacuum switching valve run by the computer.
the Egr adds exhaust to the intake to assist in filling the cylinders with a volume of unburnable gasses that your engine actually generates as a product of combustion.
When you fill the cylinders with this gas, and the air, and the fuel, you need less fuel to burn the air that's been diluted with a gas that doesn't burn. The end result is less detonation on cheaper gas, and the power output is about the same because compression is all about compressing the mixture of air and fuel into a specific volume to intensify the explosion that pushes the piston back down the cylinder..if that volume doesn't change, the explosion is obtained with less actual fuel and less emissions.
Old Jul 31, 2007 | 08:33 PM
Benny42's Avatar
Benny42
Not to argue here, but the diode is being used as a switch. If done right, it will pull the egr temp switch lead to ground when the soleniod pulls in. That is the feed-back the ecm is looking for. The egr switch has to change states when commanded or you get a code32.
Benny
Old Jul 31, 2007 | 08:49 PM
Cartier1's Avatar
Cartier1
Benny
but in my case is it better to use the resistance?? i mean not the solenoid cause it is disconnected from the valve,i have no valve on the new manifold,does the resistance does the job better?????
cause the solenoid is not reading the pressures without the valve and maybe the values are low and the readings help to the fuel mix at idle,what you guys think about it??
And thanks a lot for the quick answers!!
To EGR question "diode trick"
