Almost got engine out...3 more bolts?!
Old Jul 28, 2007 | 07:47 PM
rap87's Avatar
rap87
Default Almost got engine out...3 more bolts?!
Got the engine separated from the bell-housing, however, looks like I have I believe a torque converter. It has 3 bolts, I was lucky and was able to get one, however, when I try to get the other 2, it just spins around, and there isn't much space to put 2 sockets on the bolt head and end. Any suggestions?!
Old Jul 28, 2007 | 07:52 PM
Pete K's Avatar
Pete K
Use a large screwdriver or prybar to hold the flexplate from turning. Hear the bolt you wish to remove for 30 seconds with a propane torch, and tap it loose with a box wrench and your palm. Heat is needed to break down the loctite the factory applied to the threads.
Old Jul 29, 2007 | 12:38 AM
rap87's Avatar
rap87
Gotcha, where do I put the screwdriver? Through the little holes or do I just wedge it somewhere?
Old Jul 29, 2007 | 09:23 AM
dans87vette's Avatar
dans87vette
In a gear tooth or hole in flex plate, just be careful not to damage anything. Don't forget your Torque Converter weights around 40+ pounds, esp. with fluid in it.
To Almost got engine out...3 more bolts?!
