from what i know is there only 1 bulb type for our foglights? i have a 94 and just changed my headlights out to the SS ones. And i hate that they dont match.. is there any bulb i can use in my fogs to make them look closer to the same?
found a superwhite bulb on ebay for our foglights but i dont know if its worth it cause a lot of ebay stuff is junk
The factory fog light bulb is rated at 34-watts. Bulb#880
You can upgrade to a brighter 50-watt fog bulb without any issues. Bulb#885. If you upgrade, replace your 10 amp fuse with a 15 amp fuse to keep it from blowing. It's the one labeled "Tail Fuse" in the fuse panel I beleive.
The owner's manual might say. Or just pull one fog bulb out and see what you have. Takes like 10 seconds to remove. There will be a number right on it.
