Brake Upgrade
The turn off on the local 1/8th mile strip is coming up too fast and I'm running out of brakes.
I want to upgrade my 93 C4 fronts and keep the stock wheels. I don't need to hang C5 units on the front. Whats
the most effective cost efficient way to do this. I drive this vehicle. I don't worship it. Gold plated hydroginized
rotors arn't necessary.
I would think that you first need to make sure that your brakes are working properly - not fading etc. I don't see any need for C-5 brakes either.
Your stock brakes should handle that use very well. First thing is to figure out what's wrong. Is it fading (when was the last time the fluid was flushed)? Are the pads glazed, rotors messed up? Is the braking even, or could some of the calipers not be pulling their load? Booster working right?
EDIT, just read your sig (I have them shut off). If you have the 12" rotors up front it is fairly cheap and easy to change to the 13" (J-55) upgrade. This will help some. Do a search for 18carfan, he has a great write-up on this with part numbers - you just want stock 13" rotors (left and right), the caliper and caliper mounting brackets ( and all the pins, bolts, etc).
Good Luck,
Pete
[Modified by PeteL, 3:50 PM 11/2/2001]
Plain old every day 13" rotors, stock J55 calipers, J55 brackets and associated peices parts is all that is necessary. SS lines make little to no difference in stopping distance.
Stock rubber lines can screw up and make the brakes hard and should be checked.
J55 is the upgrade, if that car is not J55 to begin with (RPO should be listed).
Pete
With ABS you should just be able to stand on the brake pedal after the traps and stop quickly and easily.
If the rubber lines are not up to the job of delivering the required pressure to the calipers, you will experience longer stopping distances, and a mushy pedal, which, makes the driver less confident in the braking power available.
I do agree that the GS calipers are an improvement, but only by a matter of degrees (or is that de grease??). A good quality pad and bigger rotors will help. I just installed EBC Greenstuff pads. very nice. QUIET!!!!
Basically, for $300.00, you can get 85% of the braking power of a high dollar brembo setup... may not have the high-techness thing, but will do the job... also, it will not be as resistant to fade, but, when you are only laying into them once an hour, who cares!
I would also recommend the bias spring. depending on year, it goes into the master cylinder or the diverter... it causes more brake pressure to go to the back brakes. which, in turn, shortens stopping distance. I have one, but have not installed it... my master is of questionable lifespan right now...
the bias spring is about 12.00 or so from any number of corvette parts suppiers.
[Modified by bogus, 10:35 AM 11/3/2001]
