Help with drivebelt tensioner
Old Jul 29, 2007 | 04:27 PM
mdyou2's Avatar
mdyou2
Default Help with drivebelt tensioner
I have searched all over this forum and haven't found an appropriate post to answer my question.
I can find no marking or range indicator on my belt tensioner. I had no problem moving it with the breaker bar to remove the belt (replaced noisy air pump), but I'm wondering if the tensioner on the '87 L 98 is a totally automatic operation. Or am I missing something basic?
No, I don't have an FSM. That's my bad, but I am ordering one next week...
Mike, Ojai, CA
Old Jul 29, 2007 | 05:05 PM
REDC4CORVETTE's Avatar
REDC4CORVETTE
The tentioner just bounces up and down as it needs to .Their is some marks on the tentioner you can to use but ,if it is stock I would not worry about it.
Old Jul 29, 2007 | 05:08 PM
Mark C5's Avatar
Mark C5
St. Jude Donor '08-'09-'10
The tensioner is spring loaded and requires no adjustment. The indicator just shows that it is not worn out and is applying the correct tension. As long as you are not experiencing any belt slippage, I wouldn't worry about it.
Old Jul 30, 2007 | 09:27 AM
89 Bob L's Avatar
89 Bob L
The tensioner is spring loaded and self adjusting.
Old Jul 30, 2007 | 11:18 AM
JAKE's Avatar
JAKE
On my 86 the markings are very faint and I have to look really closely at a certain angle to see them. Yours may be the same.
They're located on the top.
Jake
Old Jul 30, 2007 | 12:43 PM
mdyou2's Avatar
mdyou2
There seems to be concensus...thanks, guys!
Mike
Ojai, CA
To Help with drivebelt tensioner
