how in the hell do you get to this plug???
Old Jul 29, 2007 | 07:56 PM
finally_got_it's Avatar
finally_got_it
Default how in the hell do you get to this plug???
im changing plugs and i was wable to replace all except the very back one on the passenger side..i got it out but i cant get it back in there..any tips for reaching that damn last plug port??
got it finally!!!!!!!now i cant get enough leverage to get the damn plugwire boot back on the plug....damn i wish these were hemi-type motors w/plug on top!!!
95 lt1 automatic
Old Jul 29, 2007 | 08:04 PM
Da Mail Man's Avatar
Da Mail Man
...would be nice if you posted the year in your question.....
Old Jul 29, 2007 | 08:40 PM
klkordzi's Avatar
klkordzi
I remember an old trick for starting spark plugs which is to put a length of gas line in the the enf of the plug and use it as a flexible extension to get the plug started.
Old Jul 29, 2007 | 08:41 PM
5abivt's Avatar
5abivt
small hands and its easy.
Old Jul 29, 2007 | 08:52 PM
My Jersey Girl's Avatar
My Jersey Girl
I used a hose at the end of the plug and had my back toward the motor whit the plug and hose in my right hand than try to feel where the plug hole is with the plug and use the hose to install the plug.
Old Jul 29, 2007 | 09:11 PM
STL94LT1's Avatar
STL94LT1
This may sound a little crazy. But, when I had the stock exhaust on my 94. I would sit facing forward on the passenger's front tire, lean back, and with my left hand get the spark plug started.
Old Jul 29, 2007 | 09:24 PM
cv67's Avatar
cv67
St. Jude Donor '05
Remember tothrow a little antiseizeon the threads, it will help it start a bit easier and preent the threads from galling.
Old Jul 29, 2007 | 10:17 PM
champ's Avatar
champ
From underneath - no problem at all.
Old Jul 29, 2007 | 10:22 PM
H P Bushrod's Avatar
H P Bushrod
Moderator Emeritus
St. Jude 15 Year Donor
CI 5 thru 12 Veteran
St. Jude Donor '09 thru '23
A flex-head socket with a long handle worked well for me.
Old Jul 29, 2007 | 11:01 PM
Corvette Kid's Avatar
Corvette Kid
Large Impressive Member
From: Good health is merely the slowest possible rate at which one can die
St. Jude Donor '04-'05-'06-'07
Ain't tinkering with cars fun? Good headers and no A.I.R. crap make plug changes so much nicer.
Old Jul 30, 2007 | 10:12 AM
Bill Hetzel's Avatar
Bill Hetzel
Use a spark plug socket that has a hex on it and a box end wrench.
Old Jul 30, 2007 | 10:38 AM
black_771's Avatar
black_771
Hey! That's a good idea! Mine has a hex on the end too and I never even considered that. The obvious can be painful if you never even look it.
Old Jul 30, 2007 | 10:49 AM
Strick's Avatar
Strick
I made a special tool just for this:
just a little welding of a socket onto a 9/16 wrench
Old Jul 30, 2007 | 11:22 AM
Bill Hetzel
Neat tool Strick, I like making specialty tools, I made a belt tensioner tool the same way in about 5 minutes.
Black, it's easier if the wire loom bracket is removed too. When i reinstall that plug, I put the plug in the sparkplug socket with a 1 inch extension to get it started. The short piece of hose that the otherguys mentioned works good too.
Old Jul 30, 2007 | 11:49 AM
Da Mail Man
...i drive an 88 and what i do is place the spark plug socket onto the plug and THEN the ratchet....i then loosen the plug and remove the ratchet and socket and unscrew with my fingers.......if you unscrew the plug to far out with the ratchet "installed" you won't be able to remove it and you will have to screw in the plug a little way to do that.....
Old Jul 30, 2007 | 12:27 PM
rickneworleansla's Avatar
rickneworleansla
I use this one along with one other socket length. I can get all plugs out in under 20 minutes.
http://cgi.ebay.com/ebaymotors/CORVE...spagenameZWDVW
Old Jul 30, 2007 | 01:06 PM
pianoguy's Avatar
pianoguy
Thanks for the link - just ordered me one of those
To how in the hell do you get to this plug???
Old Aug 1, 2007 | 09:25 PM
89 Bob L's Avatar
89 Bob L
I'm putting that on my xmas list
Old Aug 1, 2007 | 10:59 PM
BrianCunningham's Avatar
BrianCunningham
From: Boston, Dallas, Detroit, SoCal, back to Boston MA
Last time I did mine, that's exactly what I did.
I've ordered one of these for next time
I got mine from Mid-America, but I don't see it in their on-line catalog.
Old Aug 1, 2007 | 11:06 PM
RRT vette's Avatar
RRT vette
Removing the pass side inner fender helps much.
