Thread Help
Old Jul 29, 2007 | 10:39 PM
redvette6spd's Avatar
redvette6spd
Default Thread Help
Tried using the search and no luck. Looking for info or thread for 96 a/c blowing through defrosters and the floor fix. Thanks
Old Jul 30, 2007 | 12:41 AM
zr1fred's Avatar
zr1fred
Veteran: Marine Corps
Generally, that means you've lost the vacuum from the engine, and the "default" position is blowing through the floor and defrost. Check your vacuum connections for a broken or disconnected line. If that's not it, you probably have broken connection on the controller,or possibly a bad controller. It's to dark to go look at mine, and I can't remember the vac locations.
Old Jul 30, 2007 | 08:59 AM
redvette6spd
Old Jul 30, 2007 | 10:28 AM
RollaMo-LT4's Avatar
RollaMo-LT4
St. Jude 15 Year Donor
2021 C4 of the Year - Unmodified Finalist
St. Jude Donor '10 thru '25
This might help
http://forums.corvetteforum.com/show...=ac+controller
Old Jul 30, 2007 | 11:08 AM
coltcarbine's Avatar
coltcarbine
I had the same problem on my '96.
For me, it was the controller under the dash.
$600 later and two days at the Stealership and it was fixed.
Looking back, I should have tackled that problem myself.
cc
Old Jul 30, 2007 | 11:30 AM
zr1fred's Avatar
zr1fred
Changing the controller ranks right up there with heater cores The controller isn't the thing on the dash (it's on the firewall)
Old Jul 30, 2007 | 12:04 PM
zr1fred's Avatar
zr1fred
Pull the passenger side engine injector cover. There should be a three way vacuum connector that plugs into the plenum. That is the vacuum supply for the air conditioner. I just checked mine and one of the "****" was bad! Looks like off to the parts store for me! (actually hadn't had any problems....yet!)
Old Jul 30, 2007 | 12:09 PM
Mark C5's Avatar
Mark C5
St. Jude Donor '08-'09-'10
Click on "Search this Forum", type in "AC vents", you should get about 3 pages of threads. Not all will address your problem but many will. Best of luck.
To Thread Help
