thanks guys It is fixed!I have read the sticky but I did not see much on the 96 lt1 pcm section.I have a running hot problem,It seems like the fans wont come on unless the ac is on auto.Then the car cools just fine,but if you leave it off (no ac) the car gets real hot unless moving.In other words the fans do not come on without the ac but the cooling system seems fine when moving.Any suggestions.?
Reason: problem solved
So it is normal? have you guys left it alone because today when I shut it off I could hear the radiator bubbling and the oil seems to smell burnt although it looks o.k.I would like to fix this if possible or should I just leave it? thanks
Press the button that is to the right of the steering column that says "gauges" and scroll through the different ouputs by pressing and releasing the button. The output of the digital display will change.
The digital gauge's sensor is on the outside of the water pump, the analog gauge's sensor is in the passenger sides head. The PCM uses the digital's imput to activate the fans which come on at 228*. The digital gauge is the one to watch.
