Indecision mode - Cam choice
Mechanic has quality engine builders.
Probably going 383, maybe 396 route, hell maybe 406.
Have SR. Not really wanting to try to sell it and buy MR.
Need heads, might go AFR 195 Eliminators.
Shooting for 10:1.
Because of the SR, should I go with the 219 LPE cam or could I go more aggressive like a 230/236?
Pros/cons for going 219 and / or a higher duration cam?
Shooting for 10:1.
Pros/cons for going 219 and / or a higher duration cam?:bigears
Here are the elements I would (am) considering when picking a camshaft
How much "really" can you get away with as far as emissions?
Cylinder head...the better flowing, low lift, small port head will need less camshaft to perform
Big cam shafts doesn't mean duration as CCA has several hyd roller high lift profiles to design a custom camshaft
beehive springs cut wieght down and thus delay "pump up" a little longer
Your MAP sensor will make it more difficult to tune larger camshafts
You have to balance the airflow (intake and exhaust sys) with the head and cam capabilities.
Here's my suggestion...torque biased
1) fully port the SR runners and base (otherwise stick with the L98 heads)
2) Get the AFR 195 elim (not the competition port just full CNC), ...upgrade to hollow valves if possible/affordable
3) get the CCA behive spriings 26918
4) get a custom cam design to complement the broad torque curve of the SR, full exhaust, and stroker....224/224 on a 114 lob sep, 4 deg advanced...profile # is 3192 (0.605" lift) add 6 or 12 deg in exhaust for power aides.
5) budget for good quality valve train components ($1K) like 2x roller rockers
6) Add as much cubes as you can afford
7) enusre exhaust (you have headers right?) and torque converter are up to the task...
And yes, I am running headers. Hooker # 2149's with true duals so my exhaust flows real good.
I looked at the comp cams springs with that part number and it says good for .600 lift, but the cam you recommend says .605 would that be an issue?
When I used the 230 deg version of the 31XX. I had to "fit it" using keeper that provided an extra 0.050" of installed hieght due to the 1.6 ration=.622 lift and the .575" maximum lift of the valve springs I was using at the time. Then I had to clearance the whole thing with the self-aligning rocker! Gotta love being on the ragged edge!
Also check with AFR to see what springs they are using...just a striaght or a tapered/beehive arrangement.
Others mentioned above some great cam choices and you should factor in their experiences to your decision...in the end its your car. I think that the cam I suggested is very much the street cam with a broad flat torque curve. Should you want more "fun" in the 6000/6500 range then an increase in duration is warranted.
