LT4-replace or rebuild?
Old Jul 31, 2007 | 07:08 PM
96BLKLT4's Avatar
96BLKLT4
Default LT4-replace or rebuild?
My LT$ has over 115,000 on it and I am considering replacing it or rebuilding it. If I could get a crate motor that would be the easy out however all SBC have the rear mount distributor and the LT4 of course has the front mounted opti spark. My intent is to incrase performance slightly but have a reliable durable vehicle. Any comments?
Old Jul 31, 2007 | 07:52 PM
RichS's Avatar
RichS
I would rebuild it. It will be a heck of alot cheaper than a crate LT4. Then while it's apart you can have the heads ported, throw in a bigger cam, ect.
Old Jul 31, 2007 | 08:14 PM
Mojave's Avatar
Mojave
Is there anything actually wrong with your engine? LTx can go for a lot more than 115K. I know of a Camaro that gets autocrossed regularly in F Stock that has 370K on the original, unopened motor.
Old Jul 31, 2007 | 08:35 PM
STL94LT1's Avatar
STL94LT1
Old Jul 31, 2007 | 08:36 PM
93-383's Avatar
93-383
if there is nothing wrong major wrong with the engine. I would just rebuild it. Change the pistons and bore 30 over just to have a new cylnder wall. New brngs,wtr pump, oil pump, rods(maybe), OPTI (definantly), align bore the mains, and deck the heads and block. My build to a 383 with new heads parts cost about 3.3k you can some money for the crank. just remember if you must have the rotating assembly balance if you take my advice and replace the pistons or rods.
Old Jul 31, 2007 | 08:51 PM
bogus's Avatar
bogus
why bother? I have 163k on my LT1... BFD.
And don't diss the opti. Sure, it can be a pain, but the 2nd gen versions are very nice pieces.
Old Jul 31, 2007 | 09:57 PM
GGTOOLS's Avatar
GGTOOLS
I would diffinitly replace it ... and sell the core to me
Old Aug 1, 2007 | 12:11 AM
96BLKLT4's Avatar
96BLKLT4
actually there isn't anything major wrong with it; guess I am just thinking "old school" where when an angine gets past 100K it is time to start thinking about a rebuild or replacement. I recently replaced the WP, opti, coil, fuel pump, filter, etc. Also I was thinking of more HP...
96BLKLT4's Avatar
96BLKLT4
wonder if I could turbo or supercharge with that many miles???
Old Aug 1, 2007 | 12:26 AM
CentralCoaster's Avatar
CentralCoaster
From: San Diego , CA Double Yellow DirtBags 1985..Z51..6-speed
Sounds more like new school thinking to me. Replace the whole car at 100K or when done with payments, whichever comes first.
Old school thinking is maintain it properly, and if it ain't broke, don't fix it.
Old Aug 1, 2007 | 12:27 AM
CentralCoaster
If you are concerned about the condition of the motor, get a leakdown check done on it. I'm 100% sure my motor was in worse shape then yours with half the mileage on it. There's others out there with more miles than yours in better shape.
Old Aug 1, 2007 | 12:52 AM
Demonic85's Avatar
Demonic85
engine blows up, buy a new engine. Its cheaper than you think.
Old Aug 1, 2007 | 09:49 AM
conrad's Avatar
conrad
Here's some food for thought $3200 long block Lt4:
http://www.sdparts.com/product/12534...roletYLT4.aspx
I was considering this but conversion to LT4 was too much $$ for me. By this and wait til yours blows... Put a Hot Cam in it though!!
Conrad
Old Aug 1, 2007 | 11:50 AM
89 Bob L's Avatar
89 Bob L
Keep what you have. If it's working, don't touch it. You still have alot of miles left before considering a rebuild or replacement.
Old Aug 1, 2007 | 12:22 PM
sothpaw2's Avatar
sothpaw2
Amen. There must be somewhere else in your life to put $5-6k (assuming you have pros do everything). Europe? Hawaii? Several Cruises?
Old Aug 2, 2007 | 12:28 AM
96BLKLT4's Avatar
96BLKLT4
Oh I am no hurry to spend the $$, but again I was thinking of more HP and a rebuild or replacement would allow that. Of course on the other hand I would just as soon leave it alone and drive it. It still pulls strong and will roast the rubber off the rims (might have something to do with the 4.10's). Based on its condition I am pretty confident that it was at least adequately maintained, but not meticulously. And it does not appear to have been beat too badly. the interior is perfect and the engine fairly clean. It has been worked on (fuel rail covers are missing) but I think this is a result of a left front collision. My only problem right now is that the hydraulic clutch has a slow leak and I have not been able to find it as of yet. I just have to check the fluid once in a while. Just thought I would throw the topic out there and see what came back. I have many other projects that could use the $$ as well. Thanks for all of the feedback.
Old Aug 2, 2007 | 01:20 AM
Mr. Peabody's Avatar
Mr. Peabody
C4 of Year Finalist (appearance mods) 2019
Well you could keep most of your money, Have an LT4 Hot Cam kit put in it and some LT headers.. I gained 40 rwp in my 95 and it doesn't hurt the reliability of my dd at all
To LT4-replace or rebuild?
Old Aug 2, 2007 | 02:24 AM
cv67's Avatar
cv67
St. Jude Donor '05
Newer FI cars are built with beter metals, tighter tolerances, and becuse of F.I. they generally burn pretty clean (rarely do you see one go bad due to running too rich or lean like an old carbed motor might) -all the way around they seem to last longer.
Sounds like yours is strong, keep it running and maybe do a slow buildup on the side if your thirst is for more power.
Old Aug 3, 2007 | 12:11 AM
96BLKLT4's Avatar
96BLKLT4
how si the ground clearance? I have lowered my car and the LT headers concern me.
Old Aug 3, 2007 | 01:21 AM
STL94LT1's Avatar
STL94LT1
I didn't lose any ground clearance with my EM headers and Dynatech PowerCats.
