Failed Emissions
Old Aug 1, 2007 | 08:41 PM
FFCus's Avatar
FFCus
From: In a 1995 M6 Coupe, speeding through Connecticut
Default Failed Emissions
I failed my emissions test. I passed HC and CO, but my NOx was off. Connecticut allows 614 PPM and I had 717.
Any thoughts as to what causes high NOx levels? I've been having some temperature issues...could that cause it?
Old Aug 1, 2007 | 08:49 PM
Benny42's Avatar
Benny42
Check the operation of your EGR valve and related components. That will cause high nox. benny
Old Aug 1, 2007 | 08:57 PM
CFI-EFI's Avatar
CFI-EFI
High combustion temps raise NOx levels. As stated, the EGR valve is there specifically to reduce NOx emissions. You don't say whether they were high for the idle test or for cruising. The EGR is supposed to be closed and won't help during the idle test. Make sure your timing is properly set and that it isn't running lean.
RACE ON!!!
Old Aug 1, 2007 | 09:05 PM
FFCus's Avatar
FFCus
The printout doesn't mention if I failed at idle or not. It just gives the overall number.
I just did some searches where I actually spelled "emissions" right () and found some good info. It looks like a little love to the EGR and maybe some Seafoam might make things better.
Old Aug 1, 2007 | 09:10 PM
Chatman's Avatar
Chatman
If your EGR and timing check out, try the following:
fill tank with only 3 or 4 gallons of premium
add 2 containers of Heet Gas-Line Antifreeze and Water Remover or equivalent
Retard the timing to near the lower limit allowed.
Good luck.
Old Aug 1, 2007 | 11:02 PM
TorchRedRob's Avatar
TorchRedRob
I had the same problem last year. I unbolted the entire EGR system, but all looked well; also, the valve tested just fine. I bolted it back together, and proceeded to go pass the test with flying colors. The only variable that changed appreciably was that the first time, Richard Cranium stalled the car right before the test. After he restarted it he waited before testing, but maybe it was still in closed loop or something. (not my expertise!) Point is, it retested way under the limit the second time with no real changes. If all of your stuff checks out, maybe you too can be so fortunate.
Old Aug 2, 2007 | 09:11 AM
FFCus's Avatar
FFCus
Interesting point...they guy who did the test isn't building rockets on his day off if you get my drift...
To Failed Emissions
