After Replacing an Idnition Control Module
Old Aug 1, 2007 | 09:17 PM
RED92LT1's Avatar
RED92LT1
Default After Replacing an Idnition Control Module
After replacing the ignition control module on an LT1 are there any other procedures that need to be performed?
For example disconnect the battery to reset the computer. Or is it just plug and play?
Thanks in advance for your input!
Brian
Old Aug 1, 2007 | 09:49 PM
TorchRedlt4man's Avatar
TorchRedlt4man
From: Chicago Executive Airport, formerly known as Palwaukee
No-IL Events Coordinator
St. Jude Donor '12-'13-'14-'15-'16-'17
Did you put some sort of heat sink grease on the back of the module?
Old Aug 1, 2007 | 09:59 PM
RRT vette's Avatar
RRT vette
You shouldn't have to disconnect the battery. Do, however, use the thermal grease between the ICM and mounting bracket. If you can't find the thermal grease or it didn't come with the new ICM, you can use dielectric grease. If you use neither, the ICM won't last long.
Old Aug 1, 2007 | 10:28 PM
RED92LT1's Avatar
RED92LT1
Yes, I used heatsink compound on the new module.
The reasom I ask is because it doesn't seem as responsive as before.
Brian
Old Aug 1, 2007 | 11:02 PM
RRT vette's Avatar
RRT vette
Well, if the engine starts up cold and runs as it warms up, you know the ICM is good. You can disconnect the - battery cable, but I don't think it will help. Are you getting any codes?
Old Aug 1, 2007 | 11:10 PM
RED92LT1's Avatar
RED92LT1
No codes at all ... before, during or after the failure.
Just started running like crap while going up a long hill. I pulled over seemed to idle okay, turned around went back down the hill and then it quit.
My best guess is the ICM fires the coil when instructed by the ECM, so performance should not have been effected.
Old Aug 1, 2007 | 11:34 PM
RRT vette's Avatar
RRT vette
The ignition module is capable of providing both 4X and 360X timing pulses each crankshaft rev. Using these timing pulses the ECm processes ignition spark timing and sends an EST signal to the ignition module to acirvate the secondary ignition system. The ECM provides power, ground, and 5v reference voltages to the ignition module. A ref signal is generated each time the ECM detedts that the ref voltages have been grounded by the ICM. When the ECM detects ref signals, ignition timing can be processed.
Since the engine is running, I believe the ICM is ok. You might have a different problem going on. Like say lack of fuel pressure, injector probs, ESC system detecting knocks, weak coil, poor ECM grounds, low alternator output, restricted exhaust, ect.
Old Aug 2, 2007 | 01:36 PM
RED92LT1's Avatar
RED92LT1
Thanks, RRT for the detailed information. The car was running fine before failure of the module. I just wanted to be sure the module did not control timing or need any thing else to sync up with the ECM.
It has a slight miss at cruising speeds but I do need to replace plug wires.
Thanks for your help!!
Brian
To After Replacing an Idnition Control Module
