yes or know
Old Aug 2, 2007 | 02:12 AM
rube1975's Avatar
rube1975
Default yes or know
I have this Old solid lift corvette cam (3736097) will it work good with a stock L98?? with 1.6 rockers.
Intake opens BTDC:35
Intake closes ABDC:72
Intake Duration:287
Intake Lobe Center: 109
Intake Lift: .393
Exhaust open BBDC: 76
Exhaust close ATDC: 31
Exhaust Duration:287
Exhaust Lobe Center: 68
Exhaust lift:.399
Distance between centers: 139
Overlap:66
Old Aug 2, 2007 | 02:33 AM
CentralCoaster's Avatar
CentralCoaster
From: San Diego , CA Double Yellow DirtBags 1985..Z51..6-speed
I don't like it. And the lift looks anemic to me.
Old Aug 2, 2007 | 06:52 AM
rons85's Avatar
rons85
Well - define: work good.
Hmmm.. guess I don't recognize the part number, anyhow..
It will physically install into the motor, yes. The lift, even with 1.6:1 rockers isn't enough to have problems with the stock (assuming..) valve springs. So, yes, it will "work".
However. It will Not pass emissions here in taxachusetts, or I'd be real surprised if it did. It will also not run even reasonably well without some serious playing around with the chip (timing tables, IAC positions, probably the MAF tables to get the BLM's back right, etc..). If you are prepared to get a chip burned for it (or to do it yourself) then, by all means..
With that much lobe separation....certainly is "old school".. although I wonder how much lift (and is it Valve lift?) it's measured at?
Old Aug 2, 2007 | 07:54 AM
Pete K's Avatar
Pete K
No.
Old Aug 2, 2007 | 01:31 PM
Curveit's Avatar
Curveit
"Antique" engine part...40 yr old technology.
Old Aug 2, 2007 | 02:59 PM
CFI-EFI's Avatar
CFI-EFI
yes or know
A flat tappet L98 or a roller tappet L98? You gotta NO.
That solid cam has less lift than the hydrailic flat tappet cam that came in my Crossfire.
RACE ON!!!
Old Aug 2, 2007 | 03:45 PM
SCCA VETTE's Avatar
SCCA VETTE
It should start!! maybe even run!! Im no cam expert BUT isnt the whole design of a solid lift cam for higher RPM to keep lifters from floating or chattering (whatever the technical term is) and usually designed to come in at 2K or more and go to 7 or 8K?
I am prob waaaay off on this BUT this is the assumption that I was always under.
If this is the case wouldnt this be the worse cam you could put in a L98 with the stock TPI setup?
Cam Experts?
Old Aug 2, 2007 | 06:45 PM
coupeguy2001's Avatar
coupeguy2001
2021 C4 of the Year - Modified Finalist
Default cam
I read somewhere that the TPI cam lobes are indexed to take advantages of the runner air pulses instead of using the same geometry for the regular carb intakes
Old Aug 2, 2007 | 06:53 PM
JackDidley's Avatar
JackDidley
Thats an old Duntov cam. C2 guys can probably tell you about it. Great for a 283. Not so much in a 350.
Old Aug 2, 2007 | 07:29 PM
SCCA VETTE's Avatar
SCCA VETTE
YEA what he said lol
To yes or know
