Stand alone fuel management options
Old Aug 2, 2007 | 04:06 PM
kowalski340's Avatar
kowalski340
Default Stand alone fuel management options
Has anyone used a stand alone air/fuel management system on an L98 before. I am particularly interested in talking to anyone who has used the Apexi SAFC on their L98 Vette.
Old Aug 2, 2007 | 11:33 PM
kowalski340
does no one actually have any experiance with stand alone A/F management?
Old Aug 3, 2007 | 05:36 AM
93 ragtop's Avatar
93 ragtop
Check over in the Forced Induction section. I recently purchased a vette that has a accel DFI system, but I have yet to get it up and running.
Edit to add, Probably the reason you will not get much response here is, the factory ECM is a very good system, and unless you are running high boost, or a very radical engine, it normally is fine, provided you get the proper tuner. I personally have had great luck with Alvin at pcmforless. I have had others who have quite frankly, ripped me off. PM me if you need more details.
Old Aug 3, 2007 | 08:25 AM
Matt383's Avatar
Matt383
From: 2003 Points Champ Great Lakes Corvette Challenge; 2006/2007 Winner MSD True Street
FWIW...
I run Accel DFI.
There are newer systems out there such as F.A.S.T.
My advice is to find a reputable shop in your area with experince in one of these systems.
This is something I would NOT think of doing myself as an experienced programmer can get the most out of your set up.
My tuner sits in the passenger seat as I drive with the laptop and A/F meter on board.
He programs the system through the whole RPM range..really smooths out the program.
I had one tuner program it on a dyno for WOT only and used a canned program for the rest of the rpm range.
Car ran great at the track but ran really rough when cruzin around town.
My two cents.
Matt383
Old Aug 3, 2007 | 11:09 AM
tequilaboy's Avatar
tequilaboy
Call The Racer's Edge. Ask for Harry.
Just kidding, of course.
Curious what you are doing that couldn't be handled by one of the factory ecms with a custom tune.
Old Aug 3, 2007 | 12:20 PM
AKS Racing's Avatar
AKS Racing
I have experience with Accel DFI, FAST, and BS3. These units are typically when you get to the higher HP levels or FI. I hae not heard messed with APEX SAFC.
And the comment above regarding FI/N2O having the aftermarket ECMs, would be a great place to start.
Aaron
Old Aug 3, 2007 | 12:52 PM
Steve85's Avatar
Steve85
Cruise-In V Veteran
Running Accel DFI on my L98ish motor.
Is there anything in particular you have a question or worry about running a stand alone system?
They will work on an L98 just like any other engine and at least for early C4's the gauges will not be effected (except MPG).
And I agree with the above, unless you are running boost or something out of the ordinary, it's really overkill.
Old Aug 3, 2007 | 04:48 PM
SloRvette's Avatar
SloRvette
Cruise-In VII Veteran
I've used FAST, and BigStuff III's for stand alones. Also worked with the stock ecms. Just like was said several times above the stock ecms are capable until you add boost or get radical.
Why are you asking about an aftermarket system ?
Old Aug 3, 2007 | 07:20 PM
kowalski340
just curious thats all. I just finished building a turbo B18 91 eg6 (honda civic) which I just got into the high 12's and it's a street car and I used stand alone so I was hoping to be able to tune my new vette the same way as well.
Old Aug 3, 2007 | 09:34 PM
93 ragtop's Avatar
93 ragtop
Well you could buy a chip burner-eraser, CATS for programming, and Datamaster for scanning the car and do your if you have the capabilities to do it. Its just above my head, but if you can do the honda, I feel sure you could do the vette.
By the way, you can get it all for a little over 200 dollars. Check out the tuning section for more info, especially the stickys at the top.
Edit to add link to sticky post. http://forums.corvetteforum.com/showthread.php?t=202488
To Stand alone fuel management options
