Need Parts Help Asap
I need a rear main engine seal
I need an exhaust hanger. It is located by the y-pipe near the catalytic converter that hangs onto or near the transmission. The mechanic says the part number is 10165305?
The guy fixing the transmission says that he will put in a new main rear engine seal for free and the universal joints as well (I already have them) if I just supply the parts, The car is on the lift with the tranny out?
I am in the southern NY area just bordering New Jersey.
Best of Luck,
Aaron
They're prices seem really high, but if you're in a pinch, maybe it's worth it.
www.contemporarycorvette.com
Understand you have to go to a real muffler shop.....Midas will try to change your oil and flush your radiator.
between the end of the forward 'Y' and the front of the catalytic
converter. (There is also a lower saddle or strap that completes the
hanger - p/n appears to be 10052279).
As jhammons01 mentions, 10165305 appears to be NLA. However,
if time is not an issue, Chris at Superior has had success finding
NOS parts that no longer display in the usual parts inventory system.
You might post a WTB in the 'C4 Parts For Sale' section. There
are also several members in the process of parting out their cars
who may be able to help.
Check the sidebar along the left side of the forum for vendors who
recycle Corvette parts.
galvanic corrosion arising from the dissimilar metals.
But yeah, a good muffler shop should be able to fab up something suitable.
