I am almost finished with my rebuild. Am I the only one that gets really nervious the first time you turn the key after do engine work? I should be able to start it next weekend so I have al week to think about it
What I've done:
- new engine (ZZ4 shortblock - edelbrock intake)
- new wiring under hood and I cleand/re-painted every nut and bolt
- new suspension (all bushings, shock, ball joints, etc...)
- took apart the rearend and cleaned everything real good than reassembled
Where I am now:
I hope it all works since it was stripped to the frame and build ground up.
Yeah, I get a little nervous restarting after a teardow. Actually, I did some valve spring work on my car this weekend and haven't restarted.(fingers crossed).
