A/C Head Pressure Switch bypass pinouts needed??
My 94 coupe/6 speed had the opti/H2O pump go out in Dec and just got it back together but I had to open the HVAC lines so the charge is gone and I do not have time to recharge till later.
I am taking the car to the track this weekend and need to be able to run the passenger side fan but with the refrigerant charge out of it the fan cycling switch (three prong on the liquid high pressure line near the evap housing) holds the circuit open. this is the fan that cycles to maintain condenser head pressure.
I am not sure of the wiring circuit for closing so can someone who knows tell me which wire colors to bypass together to allow the fan circuit to run when I put the panel to a/c so the fan will operate. I have the compressor disconnected and the low pressure switch bypassed as well. just need the high pressure one in order to get the fan to work.(I hope)
The colors of wire are black, red, and either its gray or a dirty white.
I am sure the PCM grounds out to cause it to operate but don't want to cause more problems by hit or miss on trying it.
thanks in advance for any assistance you can give.
Tom
