lean 1984 w/ code 44 when warm
I have an 84 with the original crossfire set-up. The car runs ok when cold but after it is warmed up and has been sitting a while, it doesn't want to start and gets very lean with almost no power. It is setting a code 44 which is a lean mixture. I am going to change out the fuel filter and maybe the pump but since it runs ok when cold, I think that I may be wasting my money. Has anyone ever heard of this problem?
Do you have any upstream exhaust leaks? I'd clean your O2 as Scooter mentioned and check your timing. Pull your plugs and clean & gap them if needed, for starters.
Start with the basics, first. Other stuff I would check, beyond what I 1st posted:
-clear your codes by disconnecting the battery for a minute, then re-check after driving the car.
-check for a sticking EGR valve & see if it holds vacuum.
-Full tank of gas?
-Look for a good spray at the TBIs when you turn the key ON. Fuel pump will prime for 2 seconds.
-Do you have a factory service manual?
-Get a low pressure fuel gauge to test fuel pressure, regulators, fuel pump. You may have to make a fitting to run between the TBIs.
Another high interest item to check depending on the mileage is the TBs. If they have over 50K miles on the TBs, the TB shafts are worn and causing a large vacuum leak, No buts...its a fact on a CFI motor. The only way to fix this is to have them bushed. Whoever has the 145K CFI motor, I will put money on it that yours are very bad and need to be bushed. You won't believe the difference it will make on not only the idle quality, but the over performance of the motor. No buts...its a fact on a CFI motor. Send me mail and ask me how I know all this and more...
Here's a link on how to adjust the stock pressure regulator on a crossfire system.
http://www.crossfire.homeip.net/cfte...ID=18&CAT_ID=1
You don't have to do the complete disassembly if you have a quadrajet adjusting tool, because that is what is needed. Just pop the plug off and your ready to start adjusting. You will however need to get a fuel pressure gauge on the line between the two throttle bodies to see where your pressure is set. Check with Buccaneer for one of these, he can set you up.
...and Trackman is correct about most oil manufacturers pulling out the zinc content amoung other items to help cushion things internally to the motor. Rotella oil was recommended by CompCams a few months back, but even they (Shell) is pulling out even more zinc content from the Rotella oil.
The best thing to do and it it "highly" recommended is to buy a few bottles of EOS from your local GM dealer parts store and add a full bottle of EOS to each oil change and you'll be fine with the flat tappet cams and the wear issues. The bottles are 4oz. and the PN is: 12345501. The name on the bottle is actually..."Camshaft and Lifter Prelube" just in case the counter guy doesn't know what EOS is.
I hope this helps and clears up a few things for everyone. Enjoy!
Here are the main causes for the code 44 you are getting:
Typical causes for this code include:
1) O2 sensor defective or lead shorted
2) Lean injectors (dirty or blocked)
3) Water in fuel
4) Exhaust leaks upstream of O2 sensor
5) Fuel pressure or volume too low
6) Vacuum leaks
Notice #'s 2, 4, "5" and 6. Take a "REAL" good look in those areas and you should find your issues and get your CF running well again. "ANY" FP that is 12psi or under is NOT good enough for a CF to run properly. Adjust it for 14psi and you'll be fine. If your stock pump won't support that flow, install an 85-87 pump. When you blipped the throttle and the FP dropped, that "isn't" good. The motor is running too lean for sure and possibly more issues to repair.
Good luck and post your results.
