While driving last night I went to put my high beams on and got nothing. No click when i pulled the stalk back. My low beams are okay. Is it a problem with the headlamp switch or the headlights? TIA.
Could be either or both! Unplug a headlight and measure the headlight resistance and then measure the voltage on the headlight socket with the high beams on. One or both have to show a fault!
-I agree with the others regarding headlight switch. Try this --> If you have Tilt wheel, put it in the up-most position and see if you can get the headlight switch to click high/Low.
The switch most likely needs to be adjusted, which means you have to loosen the 2 attaching screws to the switch and slide it forward, or toward the steering wheel. The switch is located on your steering column just forward of the brake pedal. This switch is a PITA to get at....
