Test MAP sensor
Old Aug 8, 2007 | 07:00 PM
jimmers's Avatar
jimmers
Default Test MAP sensor
Every so often when scanning my car with Datamaster I get code 33 which is the MAP sensor. How do I test the MAP sensor to make sure its working correctly? Thanks.
Old Aug 8, 2007 | 09:29 PM
69427's Avatar
69427
From: I tend to be leery of any guy who doesn't own a chainsaw or a handgun.
Never had to test mine, but it ought to be pretty simple. The sensor outputs a voltage that varies according to the manifold pressure. You could put a Tee in the vacuum line, and a short test harness between the MAP sensor and the vehicle harness, and then hook these up to a vacuum guage and a voltmeter. You should see 4.9-5.1 volts across the supply and ground lines, and a fraction of that on the sensor signal line, depending on your idle vacuum reading.
Old Aug 8, 2007 | 09:50 PM
trackman44's Avatar
trackman44
Default MAP sensor signal voltage
MAP sensor signal voltage should be at around 1-1.5volts at idle and 4-4.5 volts at WOT. Before any test check the hose to the sensor to make sure there is no vacuum leak. If in doubt, replace hose.
Old Aug 9, 2007 | 06:29 AM
Tom Piper's Avatar
Tom Piper
I would remove the MAP sensor and use a hand vacuum pump to create a steady vacuum and read the sensor with the scan-tool or a digital voltmeter.
You could vary the vacuum and get a reading at several points (low, medium, and high vacuum).
Tom Piper
Old Aug 9, 2007 | 07:55 AM
jimmers's Avatar
jimmers
Thanks everyone, it doesnt seem to hard to test. I just have to find a vacuum pump now. Thanks!
To Test MAP sensor
