Spark Plug Experts, Help
Old Aug 8, 2007 | 09:00 PM
dave_85's Avatar
dave_85
Default Spark Plug Experts, Help
What cause my plugs to look like this?
http://new.photos.yahoo.com/davidbl2...804440064756/0
My Vette is an 85 with iron Pro Topline heads. Max advance is 32degrees.
Old Aug 8, 2007 | 09:04 PM
Curveit's Avatar
Curveit
All I get is a RED X Dave...
Old Aug 8, 2007 | 09:32 PM
dave_85's Avatar
dave_85
Old Aug 9, 2007 | 12:43 AM
John A. Marker's Avatar
John A. Marker
Looks like OIL. Might be time to change valve seals. Plug is not covered with oil, so that is good. Are all the plugs like this?
Old Aug 9, 2007 | 07:33 AM
newbecorvetteguy's Avatar
newbecorvetteguy
Cause what exactly? The oil on the threads is from an external source. The plug looks pretty new, has good sharp corners. That dark shadow just looks like it hasn't ran long enough to burn off the extra fuel the from last cold start to me. The spark probably originates from the cleaner looking area on the plug. I don't think there's anything there that needs correcting. That's my SWAG anyway.
Old Aug 9, 2007 | 08:24 AM
KeyWestJack's Avatar
KeyWestJack
Old Aug 9, 2007 | 08:31 AM
vetteblack's Avatar
vetteblack
Id have concern over the white insulator, looks burnt? Too hot perhaps? How many miles are on it.
Old Aug 9, 2007 | 09:20 AM
dave_85's Avatar
dave_85
The plug has about 500mi. on it. They all look like that. I get the dark pattern on the one side of the tip in like a day. The valve seals are good. No cloud of smoke on start up.
Old Aug 9, 2007 | 11:09 AM
'Shifter's Avatar
'Shifter
St. Jude Donor '08-'09-'10-'11-'12-'13-'14-'15-'16-'17
NCM Member '09
Spark looks like it might be a tad weak...how does your cap/rotor look? Any dusting from ionization, or
blackened contacts on your cap, or pitting on teh rotor? How about teh carbon brush? Wires good-not
stiff? Check ohm resistance on teh wires....
Old Aug 9, 2007 | 11:12 AM
rick lambert's Avatar
rick lambert
I don't think I'd be concerned...at this point, plug looks pretty good, but I'd probably pull one after 5000, just to make sure I wasn't getting oil fouled. Here's a good site for you to take a look at.
http://www.dansmc.com/Spark_Plugs/Sp...s_catalog.html
BTW, what type of plugs are you using?
Old Aug 9, 2007 | 11:21 AM
Dominic Sorresso's Avatar
Dominic Sorresso
At worst, it may be a bit rich IMO. The electrode seems to have the heat band where it should be. Right at the 90d curve.
To Spark Plug Experts, Help
