My info shows lockup control to ground back at ECM.
Hot wire goes to one of the switches on the brake pedal then to TCC then return to ECM.
If you were to duplicate the brake switch somewhere would have control as desired.
I have pnk/ blk and red as the wires on the TCC brake switch.May be different for other years
The other set of wires/switch are for the stop lamps.
NB Hitting the brake disengages the TCC if activated
I have this wired up in my car. (95impSS with 4L60E). It works well but you will cause a lit MIL.
I'm not at home and I don't have the HELMS with me but it is as simple as adding one wire tapped into the TCC ground wire going to the PCM and running that new ground wire to your dash switch and then to ground.
I can get you the color and pin location of that wire in a few hours if you don't have a Helms manual.
Karl
Depends what you want to control.
Method above lets you turn it on but not turn it off if the ECM has it on.( still to ground through the ECM)
Switching the supply (or earth back to ECM) lets you turn if off when the ECM has it on , but not on if the ECM has it off.
