Testing the cold start injector?
Old Aug 8, 2007 | 09:33 PM
pack24's Avatar
pack24
Default Testing the cold start injector?
Do you test the coldstart injector the same as the rest? Will it show the same resistance? Does it stay on like the others or does it only fire for a couple of seconds?
Old Aug 8, 2007 | 09:57 PM
RRT vette's Avatar
RRT vette
You can ohm the CSV to test the coil, but it will only show 4-6 ohms. Not as much as the other injectors. It is controled by the bimetal thermal switch located in the front of the intake manifold next to the CTS. The switch as a injector connector like the injectors. It times out after 8 seconds and is only active when engine temps are below 95*. I have my own way to test it working, but the link below is provided by AGENT 86. There is also a 5 amp fuse behind the DIC. Do a archive search for CSV under my name in C4 Tech. I have posted lots of time how it works.
http://members.shaw.ca/corvette86/Co...rt%20Valve.pdf
Old Aug 8, 2007 | 10:17 PM
pack24's Avatar
pack24
Default Thermal switch????
I do have one plugleft at the front of the motor I have no idea what it's for. That may be why it's not working. Do you have a pic of it? Does it go next to the CTS sensor sticking out the front of the manifold?
Old Aug 8, 2007 | 10:29 PM
RRT vette's Avatar
RRT vette
Sorry, I have never taken a pic of it. If your standing behind the car. It is to the right of the CTS (IIRC). It has a square connector. If the CSV system is not working properly. You will have extended cranking times when cold. If you have a FSM, there is a pic of it in there.
Old Aug 8, 2007 | 10:42 PM
pack24's Avatar
pack24
Default Fsm???
I have a Chiltons and it doen't seem to show much. Is there a better one to look at.
Old Aug 8, 2007 | 10:53 PM
edoad's Avatar
edoad
Check on the really big auction site for 1987 Corvette Factory Service Manual
Old Aug 8, 2007 | 10:57 PM
edoad's Avatar
edoad
I am giving you a Bum Steer. You need the Shop Manual
Old Aug 8, 2007 | 11:54 PM
RRT vette's Avatar
RRT vette
Alright, I came through for you. This is a pic out my FSM. The end of the pencil shows where the CSV thermal switch is. Sorry, for using a pencil but it should get the point across. The switch should have a tan wire (ckt 832) and a purple wire (ckt 806) going to it. Use the link I provided in the first post to troubleshoot. It came from a FSM as well.
Old Aug 9, 2007 | 01:52 AM
Ray Quayle's Avatar
Ray Quayle
- 1986 Original Owner -
Cruise-In I Veteran
Cruise-In II Veteran
Cruise-In III Veteran
Cruise-In IV Veteran
Cruise-In VII Veteran
This one may be a bit more clear:
Old Aug 9, 2007 | 06:31 AM
senorv47's Avatar
senorv47
Have you ruled out the fuel pump and pulsator? I had the same issue and it turned out to be just that. I was chasing ghosts because I was afraid it was the fuel pump, but I changed it out and it was easier than I thought. Now the car is running excellent.
To Testing the cold start injector?
