Do you thinik the DA affects LT-1"s ?...
I ran as follows: 14.46, 14.10, 14.21 and 14.35 all while deep staged...my last pass I did not go in deep and ran 14.01 spinning like crazy out of the hole...my 60' times ranged from 2.02 to 2.13..
Now, considering the above numbers, last February in the same car, same driver (me) I got 7 passes at the National event in Richmond, Va....the air temps were from 40 to 50 degrees and the DA was from -100 to + 400...my times ranged from a low of 13.19 to a high of 13.26 for all 7 runs...my 60' times ranged from 1.78 to 1.83... a full second difference in ET due to weather alone is amazing...both tracks hooked the same with the exception of my last run tonite...
My point is don't underestimate the power of the weather conditions on your ET's if you have an LT-1...they hate the hot, nasty weather which I proved once again tonite...
Looking at the Fuzzy's numbers, it would appear that the engine's running on the fat side, which would explain why it falls off so dramatically in summer heat. Heat soak (a known LTx issue) is another likely culprit. Engines that are lean can actually pick up performance in worse air, but this is more confined to carbed engines as a general rule, and I don't think he's running lean. Some time spent with a WEGO would confirm AFR.
Maybe an Air-Gap intake would alleviate some of the heat soak, but without any "real world" test results, I don't know. I'm trying one on my own LT1, but until I get some real numbers, I won't say for certain one way or the other.
My Chevelle, on the other hand.... summer to winter, it would pick up 2.5 tenths and 1 MPH (but it was a carbureted BBC).
Robert.....5 years ago I had a new chip burned which sets my A/F at 12.9 @ WOT...I scanned it last year and it was still holding at 12.9 WOT...I really think it is just LT-1 heat soak...the LS-X motors are not affected by the heat nearly as much for some reason...
Hot weather STINKS !!
...see now you guys are just trying to make me feel better...you guys have to make 800 rwhp to get in the 13's up on the mountain...
