Code F'n 33 I hate it.
Old Nov 4, 2001 | 08:30 PM
Bat Man's Avatar
Bat Man
Default Code F'n 33 I hate it.
I payed 600 (completely new maf sensor) bucks to have this freaking thing fixed. But no, it pops back up again. Same symptoms and everything. Lack of power, and complete bog down when pedal pushed more then 1/8th the way in.
Old Nov 4, 2001 | 08:32 PM
Springer's LT4's Avatar
Springer's LT4
Cruise-In III Veteran
Default Re: Code F'n 33 I hate it. (Old Sport)
Did they change the two relays and clean the TB while they were in there?
Old Nov 4, 2001 | 08:39 PM
Corvette ED's Avatar
Corvette ED
From: Pottsville, PA. USA Home Of America's Oldest Brewery Yuengling
Default Re: Code F'n 33 I hate it. (Springer's 95)
Change the Mass Air Flow Sensor burn off relays. They are a cheap fix. Also you could have gotten a defective air flow sensor. Change the relays and clear the code.
Old Nov 4, 2001 | 08:43 PM
Bat Man's Avatar
Bat Man
I changed the 2 Relays at the same time the MAF was replaced., but the TB has not been cleaned.
I also have a really ROUGH/Cycling idle. Do you think these 2 problems are connected?
Carbon build up on the TB/IAC?
[Modified by Old Sport, 7:44 PM 11/4/2001]
Old Nov 4, 2001 | 08:47 PM
Springer's LT4
Cleaning the TB is one of GM's steps in diagnoising a code 33... pay particular attention to the back side of the throttle plates
Old Nov 5, 2001 | 12:45 AM
Aggravated4life's Avatar
Aggravated4life
Cruise-In II Veteran
Code 33 can be a high voltage on the wire..
Did you check that to determine the wire was good and the ecm was fine?
A larger Throttle body can also set this code and will run rough.
The minimum air speed screw and TPS out of adjustment can set this code too then run rough as well.
33 is also an "unrealistic amount of airflow into the intake".
Check the TPS,min. air setting and possible carbon build up.
Old Nov 5, 2001 | 10:43 AM
Vic'89's Avatar
Vic'89
Don't rule out a bad computer for a code 33.
After replacing the 2 relays and MAF sensor, I would check on the computer.
A remanufactured one is about $100.
Vic
Old Nov 5, 2001 | 07:30 PM
viii's Avatar
viii
Default Re: Code F'n 33 I hate it. (Vic'89)
Had the same deal with my 85 (way back in 89). The car would bog down, cough, stall, backfire, and die. the ECM was the culprit.
To Code F'n 33 I hate it.
