So car was towed yesterday! I thought it was because it ran out of gas. But today it has about 3 gallons and still wont start! Well I took apart that gas lid and check the wires. One has ground the other has power and the shows nothing. I disconected hoses one by one and cranked the car. Nothing came out??? is the fuel pump bad?
Have someone turn the key "on" but not start the motor while you listen in at the gas cap. Can you hear the pump prime? It should be a smooth hum lasting about 2 seconds. If you hear a crappy gurgle, or no prime, then yeah the pump is probably dead.
I can't remember the color of the wires off hand, but one wire will have battery voltage, ground, and the other is for the fuel guage sending unit. Sounds like the fuel pump is toast.
.......could be (if applies) fuel pump relay went bad.....apply +12vdc to the aldl and that should send power directly to the fuel pump...at that point crank th ecar and see if that works...if it does, i'd be looking at the realy...if it doesn't, i'd be looking at a defective fuel pump or bad wiring....
To engage the Fuel Pump
connect a fused (+) lead to terminal G of the aldl- This will cut the fuel pump on. This verifies that the pump is in working order.
Reason: additional
Well I got my brother to turn the ignition on while I heard for the prime. But I didnt hear nothing! So to put power to the G wire do I just apply it or do I have to do sumthing special?
Find a 12 volt source, like the battery positive terminal, and apply to the G terminal using a long jumper wire.
Or,
Just unplug this relay. It's the fuel pump relay. If auto, there is only one. If manual, there is two. I think it's the one closest to the driver's side if two. Wires are Red, Orange, Red again, Green w/white, Black w/white.
Jump a wire between terminals A and E (Red and Orange) of the relay connector. Key on or off. This will feed voltage directly to the pump as soon as the wires touch. Pump should prime.
....it does not matter if the ignition is on..if you apply 12vdc to the terminal, crank the car and see if it starts......if it doesn't, looks like it could be a fuel pump issue......say, have you ck'ed the fuses in the fuse panel as i think there are some that would "apply"....also, do you have a fuel pressure gauge?.if so, put it on and apply the 12vdc as above...if you don't have pressure, i'd say your pump crapped out....
I have a brand new relay in my tool box that I keep. I put it in place of the fuel pump relay already and still nothing... I will try applying power to the G wire and let you know what happens!
...if the fuses are good,
...if you have applied +12vdc to the correct pins of the aldl,
...if you are sure connections are good,
...you have no fuel pressure,
...you have gas in the tank and of sufficient quantity,
...you changed out fuel filter,
...you cannot hear pump prim or run,
...then, the pump is probably BAD
You never mention what year it is but I just went through this, I replaced the fuel pump relay, still not the issue, then replaced the fuel pump and pulsator, was a hard starting issue because, like you it finally left me towing. turns out the in addition to the fuel pump, it was the O2 senor and the MAF. Not sure what your syptoms are but try to disconnect the MAF and see if it starts. The FSM is cool but confusing. Now my car is running great until the next major malfunction, but I unstand more of the syptoms.
..i don't think this applies...he has spark but no fuel pressure and no pump prime...
Well I didnt jump the relay wire or apply it to the G wire, because with simple turn of a key one of the wires has a 12 volt back their! There should only be one wire with 12 volts right? The other is a ground and ther other I dont no! But a total of 3 wires!
