I just replaced my radiator fan, and in the process, when I disconnected the fan, the plastic connector just fell apart. I crimped on some new spade connectors, and re-connected the wiring....now the question, the fan works as it should, but I'm wondering if, as with some motors, you connect the leads one way, the fan rotates counter-clockwise, and if you reverse the leads, it rotates clockwise? If so, what is the correct rotation of the fan? New fan works great, just want to make sure it's connected correctly.....this is on an 85 with a single fan...
