Valve covers
Old Nov 4, 2001 | 10:09 PM
Kehrer923's Avatar
Kehrer923
Default Valve covers
I have crower shaft mounted 1.6 rockers arms. I ground out everything outta the stock covers and they still wont fit. The B&B ones wont fit either. DOes anyone know where to find some, or what kind I need?
Old Nov 4, 2001 | 11:04 PM
Vettdaddy's Avatar
Vettdaddy
Default Re: Valve covers (Kehrer923)
I would like to know if there is an easy way to get v-covers off!!!
I have a lot of noise on passenger side...
Previous owner did some rocker arm changes not sure what.
Thanks Cal
Old Nov 5, 2001 | 11:35 AM
Guest
Guest
Posts: n/a
I'm using GM Performance Parts chrome covers that I got from Jegs. I ground off the drippers and took out the baffles and I'm able to use a stud girdle on top of my 1.5 rockers. I'm also using a set of Earl's Pressure Master valve cover gaskets.
To help get them in easier, I took the mounting grommets off the wiper unit, will give you about 3/8" more clearance, you will have to get some large washers to go under the 3 mounting bolts.
HTH
To Valve covers
