Solar Battery Chargers?
Old Aug 10, 2007 | 02:15 PM
Cold_B's Avatar
Cold_B
Default Solar Battery Chargers?
I recently retired the corvette from DD duty, and I want to put a solar battery charger on it to keep the battery full for when I do drive it. It's parked outside, in a pretty safe spot with lots of sun.
Would something like this work? Is there a particular one that you have had success with?
http://www.siliconsolar.com/Solar-Ca...ger-p-139.html
I like this one because it plugs into the cigarette lighter to charge, but they suggest using a charge controller as well. Does Summit sell one? I haven't been able to find one.
Thanks!
Old Aug 10, 2007 | 06:55 PM
69427's Avatar
69427
From: I tend to be leery of any guy who doesn't own a chainsaw or a handgun.
Been using a similar type for years. I bought a couple of the types used in VWs during transport and storage. The '84 ECM seems to like to run the battery down (I'm using a smaller lighter battery). Works well for me, and the price was reasonable.
Old Aug 10, 2007 | 09:53 PM
jfb's Avatar
jfb
The one you linked to sounds very good. Good price and enough current (current must be greater than 100 ma.)!
Old Aug 11, 2007 | 09:35 PM
DanZ51's Avatar
DanZ51
Not the cheapest... but the U.S. Army uses these http://www.pulsetech.com/
They're big on the models that remove sulfate buildup, but I've used the model that charges and de-sulfates with good results.
To Solar Battery Chargers?
