ive never seen these high oil temps 232 with 182 coolant is this normal,oh and i have a huge oil leak from the front of the motor,where's a normal place form such a huge leak,just wanted to know before i remove all the accessories! please help!
No that sounds bad.If the oil level is really low due to your leaks it will heat up. Leaks could be front crank seal,timing cover gasket,inlet manifold to block(usually just gasket sealant there).
