Supercharging
Old Nov 4, 2001 | 11:56 PM
A's Avatar
A
Default Supercharging
From the things I've read, both here and in books, it seems like anything you do to make more power tends to rob from power somewhere else; It's always a big tradeoff between low end torque and high end horsepower. What will increase power accross the bar? Does a supercharger accomplish this?
Old Nov 5, 2001 | 12:50 AM
scorp508's Avatar
scorp508
Default Re: Supercharging (A)
Well, a supercharger robs the engine of some power in order to turn it. Yet.... the gains BACK from it are much larger. :) I like superchargers, they are go fast NOW systems. :)
Old Nov 5, 2001 | 12:53 AM
A's Avatar
A
Default Re: Supercharging (scorp508)
I really really really really really want a SC :yesnod: I have always wanted a forced induction car (more specifically a turbo, but that's too much plumbing!).
Old Nov 5, 2001 | 01:13 AM
scorp508's Avatar
scorp508
Well, it seems that the L98 is a good engine to do it with. The '87 has a low compression ratio of 9.5:1, that is a good starting point. :) It might be a good idea to strengthen the bottom end though. ;)
Old Nov 5, 2001 | 04:13 AM
Z06_BluByU's Avatar
Z06_BluByU
I;ve been considering putting a stuffer on the '93... however, I;ve heard mixed reviews.. usually negative about supercharging.. (I still wanna try it though.. :) )
Old Nov 5, 2001 | 05:51 AM
TOEMAN's Avatar
TOEMAN
Default Re: Supercharging (BluByU)
thinking about the same thing, Procharger sent me some literature, looks like that's the way to go. (intercooled) all you have to do is fork over $4500.
Old Nov 5, 2001 | 10:17 AM
bellmd's Avatar
bellmd
I just bought and had installed the Vortech SQ trim kit for my 94 LT1 automatic. The installation was VERY difficult according to my mechanic and the instructions were less than perfect. While he only charged me $1350 for his 4 days of hard work, I think he got the raw end of the deal as it took alot of time and trial fitting parts/hoses, etc.
I've only had the car back for 4 days now but it runs like a scalded cat on the top end. I can really feel the blower come on strong above 3000 rpm and it is very tame while just crusing around town. Now I'm looking at a gear upgrade....it never ends with this madness!
Old Nov 5, 2001 | 10:45 AM
ZylaRace's Avatar
ZylaRace
Default Re: Supercharging (bellmd)
A,
To answer more of your Q,.... An SC will help the mid to top end of the engine RPM. The way the SC's and turbo's work, they are regular NA engines down low. Typically about 3K RPM the induction starts to work. From here on up, you have positive manifold pressure. The more RPM, the more boost,... i.e. More manifold pressure. The max boost depends on the pulley size/gear ratio of the SC.
I should point out, that an SC will force an L98 to continue to breath where it typically runs out of breath. i.e. You can have your bottom end and top end as well! For an LT1/4, an SC will help the good mid-> high be even better.
Old Nov 5, 2001 | 11:36 AM
A's Avatar
A
Default Re: Supercharging (ZylaRace)
So if I were to supercharge the motor, would it be best to keep the stock base, plenum, & runners instead of going to a super ram then?
Old Nov 5, 2001 | 11:41 AM
scorp508's Avatar
scorp508
To be honest, I can't think of any supercharged super ram engines. I bet they are out there, and creating crazy torque. :)
You'll spend as much on a supercharger as you would to rebuild to and possibly a budget 383.
Old Nov 5, 2001 | 11:58 AM
miker61588's Avatar
miker61588
SUPERCHARGERS OWN!!!!! :D
Old Nov 5, 2001 | 12:00 PM
FoolCrzy's Avatar
FoolCrzy
I've heard the SuperRam can't handle much boost. I think the issue is the lid not being strong enough to seal well, with the added pressure. I'm thinking of SC'ing my engine at some point...
Well, now I see Miker has a SC'ed SR...
[Modified by FoolCrzy, 11:01 AM 11/5/2001]
Old Nov 5, 2001 | 12:02 PM
jeffie86/96's Avatar
jeffie86/96
A supercharger will help high or low end power depending on the underdrive or overdrive used to spin it, I would not want to try one on a stock 2 bolt main cast crank , cast piston engine though.
Old Nov 5, 2001 | 12:10 PM
FoolCrzy's Avatar
FoolCrzy
Default Re: Supercharging (jeffie86/96)
Any idea how much boost I could run with my ZZ4 bottom end and approx. 10:1 CR??? I'm thinking 6# would be fine, but could I go to 8# with an intercooler???
[Modified by FoolCrzy, 11:11 AM 11/5/2001]
Old Nov 5, 2001 | 12:16 PM
jeffie86/96
Default Re: Supercharging (FoolCrzy)
Considering you are already running a very high compression ratio I wouldn't use a blower however if you dropped it down a few notches you could probably use 6 to 8 psi without too much trouble, my experience is limited to Detroit Diesels with superchargers. sorry
To Supercharging
