lightweight flywheel
Old Aug 11, 2007 | 02:04 AM
grandsport504's Avatar
grandsport504
Default lightweight flywheel
i had a fidanza lightweight flywheel installed along with a new gm clutch and pressure plate at a corvette shop in the new orleans area. the flywheel said it was pre-balanced but i said i didnt believe and he just stuck it on there anyway and now from 4k rpms up my shifter shakes violently. i also have lots of clutch chatter at idle and under 2k rpms especially with the a/c on. any help would be appreciated.
Old Aug 11, 2007 | 03:09 AM
bogus's Avatar
bogus
hm... the fidenza is NOT balanced. It's set to the base balance of the DMFW, not to the match balance your engine needs.
the easiest thing is if you have the old DMFW, remove the fidenza and get it match balanced.
otherwise... yuck.
Old Aug 11, 2007 | 04:23 AM
grandsport504
otherwise... yuck.
looks like ill be getting my flywheel balanced for free
any machine shop can match the balances?
secondly, ive had this flywheel on for about 5 months now and ive ran it at the track and on the street every weekend. would this cause any damage to my engine? if so what kind of damage?
Old Aug 11, 2007 | 08:48 AM
JLeatherman's Avatar
JLeatherman
Damage is unlikely, but if you ran it a long time that way you might lose your rear main seal prematurely.
I'd look for a good shop to match balance it, but many machine shops are up to the task.
Lastly, the clutch chatter might not go away when you get it balanced. I've heard that switching from the DMFW to a single-mass causes the clutch chatter, even if it's properly balanced.
Old Aug 11, 2007 | 09:01 AM
grandsport504
I think Im screwed because I cant find my DMFW!
Old Aug 11, 2007 | 11:11 AM
MSR's Avatar
MSR
those flywheels come with 2 different weights, neither is bolted on. do you know if it was bolted on with/without a weight? one of the 2 weights is actually pretty close to balanced in LTx engine, btw.
that resultant vibration will be more damaging to a cast crank than a steel one. it's very difficult to quantify it, but i'd guess the extra stress it puts on a cast crank is more than 2X the equivalent miles.
-michael
Old Aug 12, 2007 | 01:45 AM
grandsport504
-michael
No weights were in the box, just the flywheel.
Old Aug 12, 2007 | 09:01 AM
No Go's Avatar
No Go
You've run this for 5 months and now wondering if it is right/damaged your engine?
I would think oil pressure/bearing damage is another area of damage.
If it still runs then...
To lightweight flywheel
