need noob help with replacing shocks
Old Aug 11, 2007 | 02:03 PM
illinest's Avatar
illinest
Default need noob help with replacing shocks
looks very straight-forward according to the helms manual!
I've got a problem with the shock rotating when I try to get the top nut loose.
These were AC Delco units that had a threaded section, then a 'box' segment on top of the threaded section.
They each have two nuts on the threaded section.
I got the first nut off by holding the 'box' segment with a second wrench to keep the shock from rotating.
The box segment snapped off when I tried to get the other bolt. Now I'm not sure how I should keep the shock from rotating so I can loosen the other bolt. Help a brutha out?
Old Aug 11, 2007 | 02:05 PM
Pete K's Avatar
Pete K
Hold the shock tube with a strap wrench.
Old Aug 11, 2007 | 02:06 PM
illinest's Avatar
illinest
afraid of bursting shock and killing myself. legitimate concern?
Old Aug 11, 2007 | 02:10 PM
Pete K's Avatar
Pete K
The fluid and pressure are in the bottom half of the shocks. The top tube is hollow. You should be able to hold it with no issue.
Worse case, you can hacksaw the shaft, just under the nut.
Old Aug 11, 2007 | 02:32 PM
BADDUCK's Avatar
BADDUCK
From: One day you're a Comet...the next day you're dust... Arkansas
In the future you might want to buy the socket that fits the top of the front shock rod. MUCH easier when you have the right tool.
Old Aug 11, 2007 | 02:34 PM
TRACKMAN2's Avatar
TRACKMAN2
the best tool i own (out af about 60 grand worth) is a 4" grinder with a cut off wheel,, cut the sucker i have a little floor jack 15 bucks i use it to suport the hub and move it up and down to get the shocks in and out...my bilstiens have an allen key in the top end of the shaft to keep it from spinning i also added a metal washer and bushing to keep the shaft from wabeling arownd in the hole....wait a minute that didnt sound right?????
Old Aug 11, 2007 | 03:17 PM
illinest's Avatar
illinest
bought strap wrench. must wait till tomorrow to finish.
thank you for inputs!
Old Aug 11, 2007 | 03:51 PM
Aardwolf's Avatar
Aardwolf
I had to use a angle grinder on one of mine to.
Old Aug 12, 2007 | 12:43 PM
89 Bob L's Avatar
89 Bob L
A strap wrench will work. While you are at it, soak the bolt with some lubricant (WD-40).
Old Aug 12, 2007 | 03:56 PM
illinest's Avatar
illinest
strap wrench was no help.
bought vice grips, mangled the crap out of the top part, finally twisted the bolt itself off.
new shocks now installed (success! very nice!)
Thanks for help!
Old Aug 12, 2007 | 04:04 PM
Aardwolf's Avatar
Aardwolf
Thanks for help!
Glad it's going! Isn't that design of the hex in the top rod of the shock a PITA?
Old Aug 12, 2007 | 06:28 PM
illinest's Avatar
illinest
yes.
actually the passenger side was so easy.
but yes.
Old Aug 12, 2007 | 06:31 PM
BADDUCK's Avatar
BADDUCK
Old Aug 12, 2007 | 09:39 PM
vinnies87's Avatar
vinnies87
St. Jude '03-'04-'05-'06-'07
Forget WD40 and use PB Blaster... best out there
Old Aug 12, 2007 | 11:02 PM
99guy's Avatar
99guy
Old Aug 12, 2007 | 11:13 PM
Bad Karma's Avatar
Bad Karma
Yeah PB Blaster works a lot better. But sometimes you just have to get violent and start cutting.
To need noob help with replacing shocks
