Brake Bedding. I am going to strangle something..
Old Aug 13, 2007 | 01:05 AM
86PACER's Avatar
86PACER
Originally Posted by C4boy
I think you may have grabbed the wrong picture. That stuff is for lubricating caliper pins, slides and hardware, but not for the back of the pads.
No. It still works just fine for the back of pads. Some guys even use regular silicone. You're talking about this stuff probably:
I tried some of that on the same set of pads per instructions, and it was total garbage.
Old Aug 13, 2007 | 01:58 AM
C4boy's Avatar
C4boy
Yep, the red CRC stuff is it. Though it's supposed to cover the entire pad. The other stuff isn't made for brake pads. It's equivalent to putting wheel bearing grease on the back of your pads.
Old Aug 13, 2007 | 08:35 AM
garychurchill's Avatar
garychurchill
I used the anti-vibration on the backs of the pads, and re-dressed the parts (pins, etc.) with hi-temp caliper grease. I really believe now that it's probably just the brand of pads. Should of got Hawks, I kept hearing only positives about it.
Old Aug 13, 2007 | 09:58 AM
Greg Gore's Avatar
Greg Gore
I don't think it has anything to do with bedding the brakes. It is more of a high frequency vibration or chatter because of operating clearances between parts. OEM pads have a compound applied to the backside of the outer pads to help prevent this. Other areas that could help would be applying a small amount of antiseize to the caliper guides. Often the pads will vibrate between the caliper guides and the piston surface or caliper frame.
Old Aug 13, 2007 | 12:56 PM
F1Fan's Avatar
F1Fan
My hawk pads squeal like pigs when they're cold.
