C6 brakes on C4
Old Aug 13, 2007 | 09:56 AM
BlackVette00's Avatar
BlackVette00
Default C6 brakes on C4
Can C6 brakes go on a C4 with an adapter or something?
Old Aug 13, 2007 | 11:19 AM
VetteMed's Avatar
VetteMed
the base C6 brakes seem to be the same as the C5 brakes, so it shouldn't be a problem.... just use the C5 adapter brackets.
Old Aug 13, 2007 | 11:25 AM
LD85's Avatar
LD85
http://www.superchevyperformance.com...4calipers.html
https://www.superchevyperformance.co...les.asp?ID=123
Old Aug 13, 2007 | 12:34 PM
Aardwolf's Avatar
Aardwolf
No they can't fit that way. Here is a thread about it:
http://forums.corvetteforum.com/show...ght=c6+caliper
Old Aug 13, 2007 | 01:20 PM
VetteMed's Avatar
VetteMed
Maybe you should have read that more closely.... I stated "BASE" C6 brakes. That thread refers to ZO6 brakes, a different beast entirely...
Old Aug 13, 2007 | 01:30 PM
Jeffvette's Avatar
Jeffvette
From: No more yankee my wankee, the Donger is tired!
You can use the base C6 brakes with out any problems. You can also use the C6 Z51 set up as well, but you need to be very careful with the placement of wheel weights.
Old Aug 13, 2007 | 03:00 PM
Aardwolf's Avatar
Aardwolf
Yep! D'oh!
To C6 brakes on C4
