No Reverse
Old Aug 13, 2007 | 12:27 PM
RichRog's Avatar
RichRog
Default No Reverse
I have an 89 6-speed that the lock-out lost it's tension and I can't get it into reverse. Can someone tell me what could have happened and what I need to do to fix the problem.
Thanks in advance!!
Old Aug 13, 2007 | 12:36 PM
Z-07 freak's Avatar
Z-07 freak
From: Why are there squished peanut butter cups in my underware?
Check the simple stuff first. Like the clutch fluid level. When it is low, reverse is a bitch to get into.
Old Aug 13, 2007 | 05:14 PM
RichRog's Avatar
RichRog
When I pull up on the rign to put it in reverse there is normally some tension on that ring now, the tension is gone. What creates the tension on that ring?
To No Reverse
