Dana 44 spider gears
Old Nov 5, 2001 | 01:38 PM
AquaMetallic94LT1's Avatar
AquaMetallic94LT1
Default Dana 44 spider gears
I think I may have to fix the spider gears in the rear end. They seem to make noise once the rearend is warmed up after driving for about 1/2 an hour. I thought the noise might be from the clutches but the noise from the rearend doesn't sound like chatter. Any suggestions on diagnosing the problem ? Whats involved in fixing bad spider gears ?
Old Nov 5, 2001 | 01:49 PM
Chris@SD's Avatar
Chris@SD
Default Re: Dana 44 spider gears (AquaMetallic94LT1)
Pretty much, you will need to replace them. What exactly makes you think that they are bad?
I would suggest the Toms Differential cold stabilized ones. Let me know if we can help as we are an authorized dealer for Tom's stuff. :)
Thanks,
Old Nov 5, 2001 | 06:40 PM
fade_to_black's Avatar
fade_to_black
Default Re: Dana 44 spider gears (2FST4U)
i am interested myself......please let me know some prices. I would like 4.10's.
-Jordan:cheers:
[Modified by fade_to_black, 4:40 PM 11/5/2001]
Old Nov 5, 2001 | 06:55 PM
AquaMetallic94LT1
When I do left or right turns like turning into a driveway or intersection, the rear end sort of groans. It only does this when its cold. The car has 65K on it and has never been to the drag strip.
I have the redline lube for non posi rearend with 4 oz of the limited slip additive in it. Its been in there for about 4500 miles.
To Dana 44 spider gears
