fan not running
Old Aug 13, 2007 | 06:25 PM
rickit's Avatar
rickit
2017 C6 of Year Finalist
Default fan not running
i noticed my temp raising high while in town not getting over 30 mph with ac off, i checked futher and the fans only come on when the ac is turned on,i have a 94 at what temp should the fan come on?i am guessing its the relay if so were is it located? thanks rick
Old Aug 13, 2007 | 06:26 PM
96GS#007's Avatar
96GS#007
Define high. Fans come on ~220*, give or take a few degrees.
Old Aug 13, 2007 | 06:36 PM
RRT vette's Avatar
RRT vette
Did this last summer.
Originally Posted by RRT vette
I spent about 45 minutes observing the coolant temperature operation range on my stock (never modified) 95 LT1 with 50,000 miles. I started the engine and let the temp rise. All of the info is while at idle and the outside temp 80*. Idle temp reached 228* before both fans came on and never saw the temp past 230* via digital guage. Analog guage was in the hash marks and showed approx. 250* from guessing, 260* being the highest number which is miss leading. The temp dropped to 217* and both fans cut off. With the A/C on the temps sat around 201-205* and never got lower or higher. This I consider normal at idle and when driving at about 55 mph the digital temp guage stays around 185-190* range.
Old Aug 13, 2007 | 07:16 PM
rickit's Avatar
rickit
right at the edge of the hash marks
Old Aug 13, 2007 | 07:25 PM
RRT vette's Avatar
RRT vette
Have you observed when the fans come on with the A/C off? Let it idle and watch the digital coolant temp. If the fans come on with the A/C on, then the relay is good.
You probably have trash buildup between the radiator and condenser.
Old Aug 13, 2007 | 08:39 PM
rickit's Avatar
rickit
fans come on with ac,whats the best way to clean it out?
Old Aug 13, 2007 | 08:50 PM
RRT vette's Avatar
RRT vette
You can use a water hose and find an opening in the radiator shround and flush some of it out OR better would be to remove the upper radiator shround and get it all out.
Old Aug 13, 2007 | 09:18 PM
FOXX's Avatar
FOXX
A little off topic, but isn't there an aftermarket "fan on" switch you can buy that wires into the original harness?
Old Aug 13, 2007 | 09:36 PM
RollaMo-LT4's Avatar
RollaMo-LT4
St. Jude 15 Year Donor
2021 C4 of the Year - Unmodified Finalist
St. Jude Donor '10 thru '25
What does the digital gauge read?
That analog gauge will get right up close to the hash mark when the digital gauge is reading 228. As long as it does not go INTO the hash mark, you should be ok. GM recommends shutting the engine down at 260.
A modern cooling system in proper working order can handle 230 - 240 degrees pretty easy. Your car should not see 240 if everything is working as it should though.
Watch the digital gauge while sitting at an idle. It should get up to 228 or so, and then drop back down. If it continues to climb up past 235, then you should check into an airflow problem. Either fans, but probably more likely trash in blocking the radiator fins.
Old Aug 13, 2007 | 11:02 PM
jfb's Avatar
jfb
Here is an easy way to clean debris out of your radiator although it isn't as good as radiator removal. I use my garden hose adjusted for the smallest diameter stream and shoot it backwards through the radiator while holding the fan so it doesn't turn. If your temps are like RRT's, your radiator is pretty clean. My 87 left idling in summer temps (no a/c on) will rise to 228 F, the main fan comes on and engine coolant drops to 211 F and the fan shuts off, and it will repeat.
Old Aug 14, 2007 | 12:57 PM
rickit's Avatar
rickit
you were right,analog gauge was way off according to digital,it did what you said,thanks alot for the help,i guess i will start watching all the dig readouts from now on,thanks again
To fan not running
